Home > Technical (L322) > Suspension reset? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
That's a weird one... Try asking Gap, they may have some suggestions, very helpful chaps... Pete
18th May 2020 8:08am |
Johnniehec Member Since: 03 Feb 2017 Location: A a Posts: 23 |
Well I tried disconnecting the battery for a couple of days, reconnected at 12:00 today as display screen isn’t working and it’s the only way to set the clock started with the three amigos and air suspension inactive but full lock right and full lock left cleared all. Alas though reservoir pressure was still 102psi same as it was on Monday, suspension still showing the same symptoms. No warning lamps, no errors or faults, select either access or off road height and the corresponding light flashes but nothing happens. Can raise the front using GAP test valves function but not the rear. Think I’ll have a look at the ecu and connections, is mine in the passenger side dash beside the CD player or in the box in the engine bay? Cheers John. |
20th May 2020 2:54pm |
Download the workshop manual from the WIKI, there is a work through for the EAS in there IIRC
20th May 2020 6:34pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
According to manual, behind the fascia on the passenger side. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
20th May 2020 7:03pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Reservoir pressure should be @ 180 psi...... .
21st May 2020 7:44am |
Yes, it’s like it’s forgotten. Started it yesterday, compressor came on and at about 1psi/second came up to 130psi and stopped, no no faults no warning just stopped at 130. |
22nd May 2020 3:53pm |
I am going to point my finger at the compressor. A "refurb" will only last so long. I spent hours and hours chasing an AIR SUS problem, before giving up and buying a new compressor. Problem solved. You should be able to buy the bare compressor and wire it up into the turtle shell.
22nd May 2020 5:21pm |
Thanks Joe 90, problem sorted. Compressor replaced and all back to normal. Only about 2 1/2 yrs and less than 10k miles since the refurb , lot of brown dust on the foam by the cylinder of the old one. New one a doddle to fit, two year warranty though it is a Chinese cheapie, might live to regret that but we’ll see. Cheers, John. |
8th Jun 2020 11:15pm |
9th Jun 2020 8:55am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1188 |
I replaced mine with a Dunlop it lasted a year good luck with the cheapie refer to CTC on here? You pay for what you get?
9th Jun 2020 10:43am |
