Home > Maintenance & Mods (L322) > Noisy Brembos...
Page 1 of 3 123>
Noisy Brembos...
According to the maintenance record the front discs and pads were changed less than 20,000 miles ago, no make was stipulated..
They are fine in normal use, no vibration and are nice and progressive, however, brake from high speed a few times and they are extremely noisy when hot, no warping is evident, they still stop OK but the noise is horrible...
Are all Brembos noisy? or does this have cheap pads fitted, with originals around £280 it's easy to see why someone would use cheapies...
If this is the consensus does anyone have a recommendation for a good pad, I don't mind fitting the originals but if there is something out there that's better....
Not had to look at performance braking for many a year, are EBC still up there... be nice to have less dust as well..?
And before someone says it I know I could slow down.... Rolling Eyes Rolling Eyes
Thanks Guys... Pete
Post #554567 20th May 2020 10:41am
pcourtney
I would say a fair few of us have EBC Green - better than most at a decent price too Smile
Greenstuff Kevlar Brake Pads
> 100% British design and manufacture
> Extra high friction compounds for better stops, these pads will improve your stopping power by up to three vehicle lengths
> Superb gloss powder coat paint finish to reduce corrosion
> Special compound ingredients that prevent "Outline Etching" eliminating brake stiction onto the rotor in damp conditions
> Unique engineering finish with noise reduction slots and edge chamfers
> Unique "Brake-In" surface coating to accelerate pad bed in after installing new pads which also guarantees brake efficiency right from install
> Super quiet braking with rubber-steel -rubber noise reduction shims on the reverse, this dampens all possible noise
> Extra heavy duty compound lasts longer that low cost standard pads
> Fully ECE R 90 approved and legal for road and off road use
Post #554573 20th May 2020 11:36am
DrRob
I've heard good things about EBC Green and my mechanic mate who works on mine for me (only few I trust!) has them on his Sport. I will be fitting them next time round. He fitted Mintex coated discs on rear and Pagid pads (FYI).
I think he will fit Mintex coated on front too when I'm up for new ones along with the EBC Green pads
https://www.island-4x4.co.uk/front-brakes-..._3900.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #554575 20th May 2020 11:43am
But but but, the green clashes terribly with the Ipanema Sand.... Rolling with laughter
I had some years ago, I'll have a look, thanks guys... Bow down Pete
Post #554579 20th May 2020 12:11pm
Weegie
Re-spray the car? Rolling with laughter John
GAP iiD BT
Post #554580 20th May 2020 12:25pm
JLR only is my advice Pete... Thats not to say EBC don't work! As i have not used them...
Textar, Mintex, Brembo (from ECP) all Censored and an absolute waste of money... Thumbs Up
Post #554581 20th May 2020 12:29pm
DrRob
Valuable advice Craig Thumbs Up I might think twice now Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #554588 20th May 2020 12:50pm
robw54
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Re: Noisy Brembos...
I recently swapped my worn discs which had started squealing when hot/low speed which had had new pads a year before - not sure of make. as I didn't do them. I then replaced for bremo discs/pads at front myself, all in was £150 ish for parts and new sensor. No noise at all now and much less fade.
Post #554590 20th May 2020 12:51pm
robw54
Less than £40 a front set on euro for brembo - throw them on and see if it improves. Cheap fix.
Mine had a large rust lip on the discs even though plenty of wear in them, the carrier sits very close to the disc so might have been the cause as thing expanded when it got hot.
The pads i took off had done about 10K and were well worn in just over a year.
Post #554602 20th May 2020 1:11pm
Mikey
Brembo don't make brake pads.
Brembo pads are made under licence (Manufacturer pays Brmebo to use their name)
EBC no longer produce Redstuff pads for the 6 pots, and advise the use of Yellowstuff. They used to be very dusty in the past, but now claimed to be a low dust pad Question
Post #554610 20th May 2020 1:35pm
pcourtney
I like to support Birtish made where I can - so will carry on buying EBC Green Smile
Brembo mainly sub contract all the manufacture of their branded Brake Pads - so poinltess paying for the Brand Stamp IMHO
Post #554623 20th May 2020 2:55pm
Mikey
Ferodo and Jurid are OEM to JLR...
Post #554627 20th May 2020 3:30pm
Thanks guys, sure I read somewhere Jurid were OE JLR.
I'll try some of theirs... Thumbs Up Pete
Post #554629 20th May 2020 3:38pm
Yep.... I wrote that
Bought some JLR pads and they were stamped Jurid..... swapped the discs and pads a year later and went for Jurid. That’s not to say they are cheap, and they seem hard to find at the mo. There is nothing that can't be fixed with a hammer😜😜
Post #554632 20th May 2020 4:19pm
Cheers..
And yes they do seem elusive... I see they now do a low dust pad for an extra £160... Shocked Shocked Pete
Post #554636 20th May 2020 4:40pm
Page 1 of 3 123>
