Home > Technical (L322) > Tow bar electrics |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 223 |
There is a white socket in the right rear corner that the factory kit plugs into, you might find somebody like PF, Jones also have a kit thats plug and play, having fitted several tow bars for different people over the years I had a voltage sensing relay, spare socket and enough wire to make my own up. |
18th May 2020 8:05pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
Open the cover on the plug on the car.
18th May 2020 9:33pm |
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 |
If it is 16pin I have a convertor which is of no use to me any longer. 2011 4.4tdv8 Vogue
18th May 2020 10:21pm |
Dizzy Dee Member Since: 26 Dec 2017 Location: London Ish Posts: 96 |
Of you mean the socket on the rear of the car, then it will be 7 or 13 pins. Like below. |
19th May 2020 6:23am |
Sorry, late night brain fade.... There is nothing that can't be fixed with a hammer😜😜
19th May 2020 6:37am |
steve1 Member Since: 29 Jan 2018 Location: manchester Posts: 56 |
It's the 12n as above with no other plugs in the vicinity |
19th May 2020 10:38am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
Here you go Steve, that would replace the lot, or you could just search for the single 12 N with ECU box, but that seems a good price to me, and you'll get all the instructions to fit it too.
19th May 2020 10:48am |
Cheers Dave I'll get on with that many thanks |
19th May 2020 11:15am |
I do have a 15 pin on my trailer and truck, stops other folk towing it. Like this. |
19th May 2020 7:57pm |
