Home > General > Foot rest too far forward
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
Is the driver's footrest on the floor (for the left foot) the same for all models of the L322? Are there different sizes/heights available?
The problem is, if I sit in a position where my right foot is comfortable for the throttle pedal and the brake, then my left foot doesn't reach the footrest. (my legs are of equal length Smile ) it needs about 50mm (2") more height.
I prefer the seat base fairly low, and the backrest fairly upright, which is probably a fairly normal driving position. I am 1,76m or 5'9", which must be a fairly average build for FFRR drivers.
Am I unique with this issue?
If I compare to the pedal positions in the D3 and RRS, the brake on the FFRR is much higher, ,and the footrest is much further forward on the FFRR.
Help Big Cry
Post #55323 18th Mar 2011 5:28am
Fox
Can't you take the rubber pad off the footrest and fit a spacer behind it?
Post #55329 18th Mar 2011 7:29am
i find i have no problem being circa 6 foot, mind you i tend not to use the foot rest much.. ... - .- -.
Post #55330 18th Mar 2011 7:30am
Don't think it's ever been different heights across Model Years.
I'd suggest fabricating yourself some sort of extension and glueing it on, or, where some 70's heels like Elton John used to! Discovery 4 HSE
Post #55339 18th Mar 2011 7:57am
Baben
Thanks for the feedback guys, yes I have already gotten some shoe-sole rubber from a shoe repair shop and glued it onto the footrest. Just wondered if there was any "factory" fix or a way to move the brake pedal down.
Post #55345 18th Mar 2011 8:05am
Baben
Plus maybe I am just too used to the D3 seating position. Strange that they are different though. I my opinion, and that of my Physio, the seating position should allow you to have both Legs at the same extension to keep your back from twisting. The D3 achieves this
Post #55390 18th Mar 2011 11:45am
anyway its so warm out where you are you should be hanging you left leg out of the window to catch some 'breeze'.... ... - .- -.
Post #55391 18th Mar 2011 11:48am
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
i've only got 'little legs' (29" inside leg) and find it too far away to be useful
just a thought? - i wonder how insurers would view changing a pedal to non manufacturers spec? - given they will use any excuse to get out of paying claims
Post #55392 18th Mar 2011 11:52am
Royle
I can reach it on my D3 and my parents FFRR no bother, you're just a midget Wink I never use it though as it just gets in my way.
Post #55393 18th Mar 2011 11:54am
i think he's just raised the foot rest not the pedals nick..
is the disc ok btw.... ... - .- -.
Post #55394 18th Mar 2011 11:58am
Baben
"you're just a midget"
Well those of us with shorter legs have more chance of being labeled "tripod" Wink
On a Eur100k vehicle, you would expect the ergonomics to be universally good for all heights of people. I mean is 5'9" THAT short?
Post #55397 18th Mar 2011 12:03pm
nick h
hi Stan
i realise its only the footrest - but insurance companies are a law unto themselves - anything they see as a 'modification' is subject to scrutiny
disc being loaded this pm hopefully - thanks Thumbs Up
Post #55398 18th Mar 2011 12:04pm
nick h
i'm only 5' 7" on a good day Mr. Green
Post #55399 18th Mar 2011 12:04pm
see what you mean nick, also the modification might become loose and foul the pdeals..
@baben , yes 5 foot 9 is to short.. Laughing ... - .- -.
Post #55400 18th Mar 2011 12:06pm
T24RES
Could you not just shorten the right leg and pull the seat forward?? Ian
Post #55422 18th Mar 2011 2:00pm
