Home > Technical (L322) > Have i got the start of a weak fuel pump |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16288 |
Seams logical to me sir... I too think the fuel pump needs checking |
17th May 2020 10:21am |
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 |
Just seen this has a constant flowof bubbles is that normal |
17th May 2020 10:24am |
This pipe has bubbles is thatnormal |
17th May 2020 10:25am |
Pic doesnt want up load its the clear ish pipe comming from fuel filter to engine |
17th May 2020 10:26am |
Right so with ignition on there is fuel flowing through that clear pipe from filter but its very juddery and bubbles in it
17th May 2020 10:28am |
JohnK Member Since: 15 Mar 2020 Location: Hampshire Posts: 61 |
Mine did exactly the same, working fine one minute, wouldn't start the next, then would.
18th May 2020 7:30am |
Roi354 Member Since: 06 Feb 2020 Location: Essex Posts: 32 |
How much fuel is in the tank?
18th May 2020 7:57am |
I hope it is the pump and not injectors came to it this morning and again it started fine as for fuel thereis just below half a tank of fuel in her |
18th May 2020 8:23am |
If you turn her off (when warmed up) then attempt a restart. What happens? |
18th May 2020 8:27am |
Same craig its been starting ok warm
18th May 2020 9:47am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
I had the same issue on my TD6 which did turn out to be the secondary pump, so worth changing it if you've ordered one, they're easy to do, just inside a panel under the N/S/R floor, you should see cross head screw if you pop underneath the car then remove the small plastic panel, you will smell of diesel once complete |
18th May 2020 10:01am |
Cheers dave i love the smell of diesel on my chips 😂😂😂 but yes i orderd one along with a bearmach filter off flea bay its like £52 i think itwas |
18th May 2020 10:05am |
Sorry £55 does this look like gooden
18th May 2020 10:06am |
Yes thats the one I remember it well |
18th May 2020 10:20am |
