![]() | Home > Technical (L322) > Electrical Gremlin Help |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
All good mate
the_ferret82 Member Since: 10 Jan 2020 Location: Hertfordshire Posts: 50 ![]() ![]() ![]() |
words quickest update... alternator is OK. Battery voltage car off = 12.45 volts. car on 14.2 so all within limits. |
managed to capture this last night after coming home. this is what the issue looks like at its worst..
roverguy7 Member Since: 15 May 2020 Location: Virginia Posts: 14 ![]() ![]() |
What you're seeing in that picture is the Medium Speed CAN dropping out. Data between TPMS and IPC cannot transmit, as well as the radio IHU loses it's ignition signal.
Thanks for the info. ill see if the car wants to play as it does not always happen and see if unplugging thte moduel helps.. i think i may have tried it but cant be 100% any more as had so much out tracing the fault now. |
its not the TPMS module. it do still get the issue with it unplugged. ill go back to the fault code reader tomorrow., |
Somewhat unfortunately, there's not much to the MSCAN on those, at least that can be separated from the circuit.
I actually managed to get the computer on the car this morning and looked at all the fault codes there was many. a lot to do with audio and the IPC, TPMS as well as other modules, infarct there was that many it was hard to tell what was a real issue and what was caused by me taking the car apart chasing this fault. so i decided to clear the faults and have a clean slate.
Been though and reread the car this morning after driving it around yesterday with the ACM removed, and so far no more random radio reboots...
That's a lot of LCM faults, how many LEDs did you install??
Im running LEd Lights in:-
IHU can be swapped without issue.
ok thank you for letting me know, ill have a hunt on ebay and see if i can find one going for a good price, and give it a shot and see what happens. do they have issues often?
after a godo hunt of Fleebay i managed of find a part number matching IHU in workign condition or so the ad says for the sum total of £23.. will update here when it arrives and it fitted. |
