Home > Technical (L322) > Possible BCM replacement |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
I doubt it's the BCM....
5th May 2020 3:13pm |
matlandy Member Since: 06 Aug 2016 Location: Crawley Posts: 134 |
Ok thank you for your reply that explains a lot |
5th May 2020 4:00pm |
I'm also getting these messages and lights on the dash if anybody has any ideas I would be grateful.
10th May 2020 7:05am |
Get the faults read, I'd guess you have a sensor out somewhere, I'd guess an ABS sensor as the fatty uses these for speed monitoring and that's one reason all of those won't work... Pete
10th May 2020 8:23am |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Just had the same dash faults on my TD6 for a few times , flat battery charged back up and same next trip , battery going flat due to failing alternator . Eventually the red battery indicator came on , just got home and alternator dead . |
10th May 2020 9:17am |
Forgot to add , also had all the same fault codes as you , on dash and when plugged the diagnostic GAPP system in |
11th May 2020 8:20am |
Still have the same list of faults Battery and charging ok. Would it list the ABS sensor that was at fault like the nanocom on my D2 did
13th May 2020 4:33am |
Just a guess but the only one I don't recognise is
13th May 2020 8:37am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
To check the steering angle sensor disconnect the battery following the disconnect procedure in WIKI. Then as soon as the battery has been reconnected do the resetting, with the engine running, turn the wheel fully from one lock to the other.
13th May 2020 9:30am |
The fault is not continuous I can drive the car to work about 6 miles but it only on the journey home that the fault flags up I think it might be down to my battery being low as had the AA jumpstart 2 weeks ago but the in-car volt meter only reads 12.6 volts when off and 14.2 when running but it's strange how it does it when the car has been driven for a bit. |
13th May 2020 4:18pm |
Those voltages are in range and acceptable. John
13th May 2020 5:02pm |
My voltages were the same. I know it should read nearer 14.7v as it does on my other vehicles. My alternator was failing under load/speed. As mentioned , I had all the fault lights/symptoms that you are currently having before finally on one journey the red battery indicator flashed quickly a few times before coming on continuously. |
13th May 2020 11:52pm |
A bit of an update on the fault I didn't realise that the fault clears on it's own when I switch the ignition off as have been clearing the fault before I have switch off the car. Is the steering angle sensor on the steering wheel end or the rack end, as this is one of the fault that has showed. |
19th May 2020 7:17am |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 222 |
SAS bottom of steering column near your feet. |
19th May 2020 7:44pm |
