![]() | Home > Technical (L405) > What’s this cross headed part called? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8363 ![]() ![]() ![]() |
I think it's called the cross headed part.....
Thanks |
Boatmechanic Member Since: 11 Dec 2019 Location: West coast Posts: 89 ![]() ![]() |
Don’t know about JLR, but to most OEMs, it would simply be a clip. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Ask for the fixing clip that holds the cover for the engine bay fusebox Ryan... |
If you find yourself at a complete dead end? I could post a couple up to you... Would rather not step on anyones toe's on here at Duckworths etc so please try sponsor first sir... |
Beach Member Since: 11 Jul 2015 Location: Bristol Posts: 54 ![]() ![]() ![]() |
LR024316 i think this is the part number |
LR024316 isn't quite the same, it is a two part clip, the one above is a single part with a thread on the bottom.. |
these are the ones in the engine bay either side of rear cowl or over the headlight access panel. This is where i look up part numbers
Sorry Pete but that part number is correct sir... Ryan’s picture only shows one half of the clip that holds that panel on👍 |
Excellent... doesn't take much to confuse me these days...
Thanks very much all 👍🏻 |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
Got these off eBay eBay Item No. 192690438547. Only a couple of quid and did the job |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 387 ![]() ![]() |
In my 2016, there are 14 of these in the engine compartment. I have replaced about 5. They are really designed poorly. They strip out fairly easy. |
