![]() | Home > Wheels & Tyres > Space Saver Wheels and Sizes |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Put the 2 into https://tiresize.com/comparison/ and make sure they are close - the OE tyre sizes should be pretty much identical to each other in terms of overall size |
I don't think you need to worry about a space saver wheel / tyre being smaller than the wheels fitted to the car. The rolling circumference will make no difference, the wheel will just rotate at a different speed.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Few tins of tyreweld and a compressor is a better choice IMO |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
online
2003 Range Rover 4.4 Litre V8 - Adriatic blue 2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8541 ![]() ![]() ![]() |
There are no locking diffs to worry about on the 322 so you won't upset the transmission, however if you go too far out of size the DSC will get the hump, it uses the steering angle and ABS sensors to determine if you are skidding, if turning a corner it expects an imbalance in speed across the axle, if you are going in a straight line and one wheel is going faster than the other then the system may think you are skidding and start taking action... Suppose you could turn it off if you use the spare,,,,
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 904 ![]() ![]() ![]() |
thanks all - I just cannot take the risk, I visit construction sites almost every day, and get 5 to 10 punctures a year |
Norm Member Since: 25 Jun 2018 Location: Mississauga. Ontario. Posts: 32 ![]() ![]() ![]() |
A better idea might be to buy run flat tires rather than mess around with micky mouse tires. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
runflat tyres need special rims that LR do not do.. ... - .- -.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Why a space saver. Why not just buy a proper wheel and tyre? Means you haven’t got to pootle, you don’t have to get it fixed there and then, and they can be picked up for cheap. There is nothing that can't be fixed with a hammer😜😜
a 21" takes up nearly all the room in my boot, so I am trying not to go down that route
Are you running LPG and not able to put under the floor?
You could always treat each tyre with Slime tyre sealant to deal with punctures, you wouldn't need a spare at all then. |
You really wouldn't want them - they give a noticeably firmer ride & the wheels are heavier. The sidewalls are much stronger, somewhat obviously, to keep their shape, so they transmit more shock to the wheels which therefore also need beefing up.... The theory is great..... |
Or another possibility....
__________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
