Home > In Car Electronics (L322) > Strange GPS behaviour |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 437 |
Yes - I replaced the GPS arial appr 3 years ago - cannot be correpted already? |
11th May 2020 12:33pm |
Piet Member Since: 22 Mar 2017 Location: Maasdam Posts: 199 |
Hi,
11th May 2020 6:00pm |
Oh and Eirik.......04-17-2001??? |
11th May 2020 6:05pm |
Yes, that's the strange thing - seems to find the satellites, but there might be something wrong with the internal decoder? I've also tried to disconnect the battery (2 month old agm Battery), tried to Reset the position, calibrate position, but I haven't found any fault on the IID tool either. Strange! |
11th May 2020 6:14pm |
Stil Ill think you’ve a problem whit the antenna.
11th May 2020 8:15pm |
ikjos Member Since: 09 Sep 2019 Location: Hornindal Posts: 41 |
Could be related?
12th May 2020 6:49am |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 338 |
I had this problem and on Sunday I replaced the receiver / aerial on the back of the car. Happy to say that after recalibration it now works. The issue was that the previous owner had either gone under a height restriction which was too low or something had hit the aerial as it was totally smashed (but couldn’t be seen as smashed from looking at the car from the roadside) and the GPS receiver was broken in two.... 😳
12th May 2020 7:16am |
