![]() | Home > My Range Rover > First RR - 4.2 SC |
essex boy Member Since: 21 Jan 2017 Location: essex Posts: 207 ![]() ![]() ![]() |
Hi and welcome
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8230 ![]() ![]() ![]() |
Nice, enjoy....
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 602 ![]() ![]() ![]() |
very nice |
JohnGalt11 Member Since: 31 Mar 2020 Location: Iowa Posts: 27 ![]() ![]() ![]() |
For the coolant warning it can be a couple of things. The level could just be low, in which Case you'd top off with 50/50.The concentration may be low. The float in the tank actually tests the concentration. Top that off with 100%, or even better, do a compete flush and refill with 50/50. The Sensor could be bad. It's a few bucks and 5 min to replace. Or the float in the tank could be bad, which requires replacing the whole expansion tank which also comes with a new sensor. If you're going to do that, might as well do a full flush, IMO. Just beware, the SCs can be a bear to refill because they have a tendency to airlock and the bleed valves are of very limited use. You may need an air compressor to force the coolant through the system and the air out. 2009 L322 SC |
bhavinp Member Since: 29 Sep 2017 Location: Leicestershire Posts: 5 ![]() ![]() |
Thanks for the tips folks.
