![]() | Home > Technical (L322) > Boot space - Pre purchase help please |
JohnGalt11 Member Since: 31 Mar 2020 Location: Iowa Posts: 27 ![]() ![]() ![]() |
I jumped in the back of my mine and took some measurements. It looks like it may just fit. There is a trim piece under the window that sticks out a about 11 cm and sets the maximum depth of the cargo area to the rear seats. Also there is a large radius left to right on the rear hatch, so the depth from the back of the seats near the sides is about 4 cm less than the depth measured from the back of the seats in the middle. I measured the cargo area depth at about 70 cm along the sides and 74 cm in the middle. The minimum cargo area width is about 114 cm measured at the bottom of the window height before it begins to taper inward toward the roof but inside the trim. The window trim piece on the rear hatch is about 47 cm from the floor, and a vertical measurement from the floor to the rear window tangent with the window trim piece is about 68 cm. In otherwords, if your dog carrier were against the back hatch it could be at most 68 cm tall before it would touch the rear window. These measurements aren't precise and are meant to be somewhat conservative. Also mine is a 2009, so if there were differences in other years, take them for what you will. So it should fit, but I would suggest that you either strap it in (there are tie downs mounted on the floor already) or put some sort of blocking between the bottom of the carrier and the rear hatch so that it can't slide backwards and hit the rear window. Hope this helps! 2009 L322 SC |
Daveb257 Member Since: 16 Apr 2020 Location: Chester Posts: 5 ![]() ![]() |
John that’s brilliant thank you, let’s hope car measures up later !
Happy to help! Good luck, and welcome! 2009 L322 SC |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
if it fits in an X5 I dont see how it wouldn't in a L322. L322 has much higher ceiling than a X5 and a deeper cargo area 2014 FF Autobiography 5.0 SC
X5 needs the rear seat dropped sadly, boots long enough but slope of rear seat and tailgate mean a lot less useable space |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1259 ![]() ![]() ![]() |
We have an L322 and have a Guardsman full dog cage. We had it originally on our P38 but had to have it modified to suit the L322 as the load area is slightly bigger on the P38.
