Home > Technical (L322) > Rear diff
essex boy
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Rear diff
Hi all
How do you know if rear diff is locking or not
Post #552685 4th May 2020 7:38pm
Nick591
Locking diff has an actuator motor on the top left of it and a cable to it. Non locking is a plain housing on the top. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #552693 4th May 2020 8:26pm
Sandyt
Yours will be electronic all s/c had electronic diff
Post #552810 5th May 2020 3:51pm
essex boy
Thanks for replies chaps what spec fluid will be required
Post #552813 5th May 2020 4:15pm
Oil specs are in the handbook and WM downloadable from the WIKI... Thumbs Up Pete
Post #552816 5th May 2020 4:38pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
2006 MY doesn't! Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #553170 8th May 2020 1:56pm
stu1
It's very simple to check - get the car on high suspension setting, get underneath the rear diff and get your hand around the top of the diff (obviously use an axle stand or or similar under the jacking points for safety) - it it's electronic you'll find a motor there.
Alternatively, jack up the car, remove the right hand rear wheel and with a torch shining towards the diff you can see the top of the diff - the motor will be very evident.
Post #553197 8th May 2020 7:03pm
Sandyt
appj62 wrote:
2006 MY doesn't!
Apologies thought it went with the engine but went with the other upgrades
Post #553204 8th May 2020 8:57pm
