Home > Maintenance & Mods (L405) > Trickle Charging Battery
peekay
2016 Range Rover Autobiography SDV8 Corris Grey
Hi all,
Just a quick question, searching didn't seem to answer my question.
Stupidly, not even sure how, I left my lights on the other week and with lockdown car is not getting used much at all. I am getting the 'battery low' warning message when I get in the car. Thought I would just put the trickle charge on it. However when looking in the manual it says battery needs to be removed to be charged? Is that right?? Are you able to trickle charge the battery and if so do you connect it up to the points under the bonnet that you would use to jump start or do you need to connect direct to the battery? If it is just connecting to points in bonnet does this charge both batteries?
Thanks in advance
Paul
Edited to add - my charger is a CTEK XS0.8 - would this do the job?
Sorry - just found a thread which answers all my questions - didn't come up in the search ! Sorry - please feel free to delete this post
Post #552524 3rd May 2020 11:47am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Posts under the hood for the trickle charger. I use a Battery Tender brand
What did you find about using this method charging the secondary aux battery? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #552540 3rd May 2020 3:31pm
I've just tried it - the secondary battery was showing 12.4v - the main battery using under bonnet posts 12.0v
I plugged in the CTEK to the posts & both showed 12.6v
Not entirely conclusive - but appears the CTEK may be charging both.
I've left it connected so I'll see if there is any difference tomorrow.
Post #552542 3rd May 2020 4:03pm
ur20v
A Trap
Your Charge is very small, it’s safe but may take many days to charge the batteries, keep check the voltages, you need to see the volts come over 13.5v while on charge to fully charge the batteries
Post #552568 3rd May 2020 8:17pm
