Home > Maintenance & Mods (L322) > coolant cap 4.4 v8 engine
Page 1 of 3 123>
Superspoons
Hi,
If you have a BMW 4.4 engine in you FFRR, could you take a look at your expansion cap and tell me what number is stamped on the top please.....???
...there is a reason behind this..honest.
Thanks Very Happy Gavin
Post #54982 16th Mar 2011 11:14am
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
280 - hope this helps?
Post #54983 16th Mar 2011 11:17am
Superspoons
Bingo!
Thanks Nick H Very Happy
That confirms the theory that TD6 and V8 models need different caps. I currently have a '140 cap' on my 4.4. The garage who looked at my car said they noticed that another 4.4 they had in had a '280 cap'.
This is strange because I can't find any supplier who can sell me a '280' cap - they all say they are the same for both diesel and 4.4. I can understand the tank being the same but it looks like the cap must be rated differently.
This all relates to this post, regarding my water leak from the cap
http://www.fullfatrr.com/forum/topic5087.html
Rang Land Rover dealership and ordered one - they can't tell whats on the cap until it arrives which will be Friday.... Gavin
Post #55016 16th Mar 2011 1:10pm
nick h
glad it helped
thats the great thing about this forum - apart from Fat Edna Mr. Green
have you tried a scrapper of RR's - probably cost you pennies
try Douglas Valley Breakers, Standish, Lancs
ask for Steve Strange
Post #55019 16th Mar 2011 1:19pm
Superspoons
Cheers Nick - I'll contact them. Gavin
Post #55129 17th Mar 2011 5:34am
pretlove
my 4.4 has 280 on the cap as well Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #55230 17th Mar 2011 5:42pm
daveo
and so does my one...thats a 280 cap V8 facelift Range Rover Autobiography 22" wheels.
Post #55233 17th Mar 2011 5:57pm
Superspoons
The Definative expansion tank cap answer :-)
Ok, I think this deserves a post as it may help someone else with the wrong expansion tank cap on their 4.4 V8 BMW engine (2003-2005).
You need a '200' cap for the BMW engined 4.4 V8 -
Not one of these -
Underneath they look like this -
The correct 200 cap is listed with LR as being for the 2001 model of the L322 - dont be put off by that, just order the part number in the picture from a LR dealer.....
Can't take any credit for spotting the difference - that goes to Gary at www.MRHLandrover.com in Hertford.
cheers Gavin
Post #58209 1st Apr 2011 9:32pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Help Needed... Which Rad Cap?
What pressure pressure cap should be on a 2004 BMW M62 V8 Rangie?
I've ordered a new one and it's arrived - but it's a 140 pressure rating - the one on the car is 200... Which is right?
Scanning the web (and using the search on here) seems to imply it should be 200 - but other sources say that this was superseded by a 140... Help!
OK - on the web this http://www.land-rover-parts-shop.com/en/ui...;year=1998
and this
http://www.famousfour.co.uk/new_parts/part_page.php?partID=14526
and this
http://www.rimmerbros.co.uk/Item--i-GRID009230 all show that I need to use the PDC000070 cap. My VIN is 4A18XXXX
This cap is 140 (1.4 bar) pressure - according to the Rimmers page, only the very very early ones had the PCD100200L which was a 200 (2 bar) pressure cap...
I'm stuck now!
Post #127762 26th Jun 2012 3:57pm
Simes
Anyone?
I'm baffled!
Post #127784 26th Jun 2012 5:05pm
from memory its the lower one for diesels and the 200 for petrol...do a search ,its on here somewhere.. ... - .- -.
Post #127806 26th Jun 2012 6:13pm
Simes
If only it were that simple Stan.
It looks like the 200 was only (officially) for the early models. Later M62's (and replacement caps) are all 140. According to my tame RR mechanic. The change was because the 200 was holding so much pressure, slightly overfilling the expansion tank would cause it to crack, or even hoses to be pushed off.
So, as I need to drain it and refill with fresh anti-freeze, I'll try the 140 for a few days and see what happens. If I lose water I'll know it's not man enough for the job.
But I have had the tank crack (and I know I'd overfilled it by about an inch in a moment of blindness).
Post #127809 26th Jun 2012 6:34pm
found the thread, hope it helps..
http://www.fullfatrr.com/forum/topic5151.h...oolant+cap ... - .- -.
Post #127827 26th Jun 2012 7:21pm
Simes
Cheers Stan.
I've got a new 200 coming in the post - so will stick with that. It appears that there is a lot of odd information out there about this - RR dealers are sure that the 140 replaces the 200.
God alone knows what's right!
Post #127829 26th Jun 2012 7:25pm
maybe a pm to dan [duckworths] might help or hopefully someone with the same engine will take the trouble to look at theres and report back ,if there is any markings that is.. ... - .- -.
Post #127831 26th Jun 2012 7:29pm
Page 1 of 3 123>
