Home > Technical (L405) > 2019 Matrix Light upgrade (Wiring)
Page 2 of 6 <123456>
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Interesting options there Thumbs Up
Post #552223 30th Apr 2020 7:36pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
It appears to me they don t use your old head lights for full matrix upgrade.
You supply them with matrix head lights normal or full laser and they mess with the module on the lights and connector ,so that the new lights will fully function on the old HID car pre 2018.
Then with their upgrades the new lights are plug and play on your old model car with full functionality of adaptive LED lighting.
Hope that makes sense.
So in short no messing with your old cars wiring! Just plug and play.
Up for $1500 for them to work on your new supplied lights and cost of you buying new model lights say around $3500/$4000.
Then new bumper, new hood, painting and fitting.
So great no touching you cars wiring, but still a big job.
Post #552240 1st May 2020 1:32am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
i dont know about that....if your view their website and instagram, FB etc they are doing extensive retrofitting as well. Their work looks pretty quality. For example they are retrofitting LED modules into Evoque lamps 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #552241 1st May 2020 2:10am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
@Jettec that was not my understanding, I may be wrong but I contacted them re my 2015 model and it was my model we discussed. In the email they clearly say we need your headlamps to retrofit full led. They also mention painting options. Also the 20182₩19 headl lamps dont fit my model. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #552242 1st May 2020 3:23am
jettec
Hi Dolf34 no if you read their information they supply the RDMatrix computer unit and program it to your new 2018 Matrix headlights.Then you have all the functions on the new Matrix lights working on you old car.
But you have to give them the new lights so they can mess with them to make them plug and play.
Then they will just fit on your 2015 car! But you will still need to replace bumper and hood plus painting.
You can not upgrade old lights to Matrix , you would have to replace the housing and the lens to take Matrix Led unit fit , so that would be a whole new light anyway.
Cam Tec Craig on this site has modified his car to the latest lights and states new hood and front bumper required.
He has pictures of his mods.
I hope that makes sense.
Post #552248 1st May 2020 7:48am
Pic below if that helps sir... Thumbs Up
Post #552255 1st May 2020 9:12am
supershuttle
This is all a bit confusing - I assume that UNLESS I want to replace my 2013 headlights with later ones to get laser brightness together with all the faff of getting a new bonnet fitted, then this is a possible option - or am I missing something?
BTW I don't drive a "truck" and neither is that thing that covers the engine a "hood" Very Happy Very Happy Geoff
Post #552258 1st May 2020 10:03am
dolph34
Hi Geoff , I have emailed them this morning to get clarification, its italy so not sure if they are working today. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #552268 1st May 2020 10:30am
supershuttle
Thumbs Up Geoff
Post #552273 1st May 2020 10:44am
Mr Tee
Ah, if you look at the pic of the manual on their website it’s a retrofit adapter. Oh well lads, need to find something else to spunk cash on ..
Post #552296 1st May 2020 2:01pm
dolph34
Hi All , got an answer re new headlight or not this morning from Italy and it seems they do the work on your original headlights please see below
My email to them,
Hi , can you clarify if i need to supply new headlights for the LED conversion or if I send you my 2015 headlights and you work on those ?
Thier response
That conversion requires to work on headlights; we need to open them.
We will remove the existing HID system (bulbs, projectors, ballast and wirings) and install our LED or Laser System.
You can personalise the styling (for example, you can choose the housing color in case of painting).
I hope this clarifies the situation but at the same time I'm not affiliated to this company and I opted for the LEDS bulbs for now Thumbs Up I may got the full LED route after another member reports back with their findings. Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #552590 4th May 2020 7:14am
jettec
Well that does sound interesting!
Why do they not have this option listed on their web site ?
If I could see the info I might go down this path.
Thanks for the follow up.
Stay healthy!
Post #552593 4th May 2020 8:02am
dolph34
Jettec, it does sound much better than having to change the lights and any bodywork + alot cheaper. Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #552604 4th May 2020 9:50am
horse86
Can you send me the contact there you’re using? I’ve tried sending them an email through their site and also an email and got no response.
Also seems the PMs on this site are jacked up again 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #552613 4th May 2020 10:47am
dolph34
I'm using the info@rdcustom.it email address , they seem to respond very quickly in the morning ( pre 10am) but not so quick the rest of the day. Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #552614 4th May 2020 10:52am
