Home > Technical (L322) > Air Conditioning |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Pressure may still be ok but not enough charge (liquid) in the system, get it recharged and see how it is. |
21st Apr 2020 9:47am |
I'd tried with a recharge kit because that was my first thought and it raised the pressure to very high straight away, so not sure if that is the issue. MY 2010 5.0 SC Galway green and sand interior!!
21st Apr 2020 12:30pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1188 |
Have you checked that the rev`s come up when you switch on the A/C that indicates that the pump is working and go down when it`s switched off? |
21st Apr 2020 12:39pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Mine had a faulty Air pollution sensor all the time I had it and the aircon worked fine..
21st Apr 2020 12:45pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
You could try running the ac on full recirculation and see if anything happens. |
21st Apr 2020 1:45pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
Do you mean no cold air coming through the vents or no air?
23rd Apr 2020 11:49am |
According to the workshop manual the TDV8 and Petrol have different types of compressors.
24th Apr 2020 4:38am |
Success!!! Today I used the Faultmate to keep an eye on the system parameters and then started filling the system with CRC AC recharge. The pressure gauge on the recharge bottle went straight into the red (about 25% of the red range) but system pressure of the AC didn't go up for a long time.
25th Apr 2020 7:33am |
Told ya |
25th Apr 2020 7:36am |
Yes you did and that's why I decided to give it another go!! Thanks!!! MY 2010 5.0 SC Galway green and sand interior!!
25th Apr 2020 7:48am |
