Home > Technical (L322) > Rear ETM diff plugs
ebajema
Rear ETM diff plugs
Hi all, I have done the front diff and transfer case oil change but the Wiki workshop manual does not show the diff plugs for the 5.0 SC, only the TDV.
On the bottom of the diff there are two candidates for the drain plugs and I want to make sure I take out the correct plug of course. Who knows for sure which on is the correct plug.
Also the fill plug, I think I have found it (driver side).
 MY 2010 5.0 SC Galway green and sand interior!!
Post #551530 24th Apr 2020 4:21am
ebajema
I eventually used the L405 workshop manual that did have the ETM diff graphic and it looks pretty much the same as the L322 diff. So I took out the drain plug and it worked! So all done now. MY 2010 5.0 SC Galway green and sand interior!!
Post #553216 9th May 2020 12:29am
