Home > Technical (L322) > 2007 TDV8 can't unlock drivers door.
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
Heres an interesting one.
2007 TDV8. Been parked up for a while. Whilst parked the battery earth is disconnected so it doesn't drain flat. Opened it with the key yesterday, no problem. With the battery connected locked it with the remote then disconnected battery earth again and shut bonnet.
Went back 5 minutes later, key in lock, turned key and the button only raised a wee bit (see photo) and door won't unlock. Nor can I open the bonnet as far as I can see without cutting off the grille. If I do that hopefully I'l gain access to the bonnet release then reconnect the battery to unlock with the remote. Anyone any experience of manually releasing the catch on the bonnet landing panel?
I don't really want to do that nor do I want to break a window.
Am I right in thinking it's deadlocked so I can't fish into the inside door handle with a bent wire to open it from the inside?
Any other suggestions welcome.
By the way its a RHD and the passenger door doesn't have the later 2nd key lock.
Thanks Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #551188 20th Apr 2020 10:20pm
Most likely cable related
https://www.fullfatrr.com/forum/topic3712.html
Post #551196 21st Apr 2020 6:50am
Dijit
Thanks but no. His doors locks and unlocks ok, mine doesn’t. His problem is with opening the door from the inside. Mine is unlocking the door or opening the bonnet to reconnect the battery. Rehab is for quitters!!!
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #551201 21st Apr 2020 7:46am
Roi354
United Kingdom 2005 Range Rover Vogue Td6 Buckingham Blue
There are door lock repair kits on ebay for around a fiver.
As your button is moving slightly I suspect you'll just need to refit the parts to get it working properly again.
After that, fit a charger point to somewhere accessible outside and stop disconnecting the battery.
As to how to get in it in your current situation I'm sorry but I can't help.
Post #551219 21st Apr 2020 9:21am
Dijit
Thanks but as you note getting into it is the issue. After that fixing it is simple. Rehab is for quitters!!!
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #551236 21st Apr 2020 10:21am
