Home > Technical (L322) > L322 2008 key
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
L322 2008 key
Hi
I've only got one key for my 2008 L322 and it's looking pretty tired. I'd like a new replacement but I'm not keen on dealer prices.
On my old Discovery 3, I bought a key online for about £40, had it cut professionally, then programmed it with my IID.
Anyone done this with the L322? Where did you get the key?
Post #548183 24th Mar 2020 9:31pm
Danwilderspin
Tbh - I had the same situation - I bought a new casing from eBay split the old one and soldered a new battery in while I was at it (not necessary if no battery problems) and just swapped the guts over took about 10mins max.
If you want a key there is a closer they bang on about on range rovers.net about £100 from Ali express about £130 from UK eBay blank keys are £10-15 so you just need blades cutting... I think by the time you have it you would break even but if you wanted to do a couple then sell it all on you’d be quids in. It looked very simple to use when you had sourced the blanks put old one in it reads new one in it writes Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #548185 24th Mar 2020 10:07pm
gilesharrison
Hmmm. That's still not that cheap.
The RR key looks identical to the old D3 key but I'm not sure if it is.
Post #548197 25th Mar 2020 7:49am
Danwilderspin
Just get this then and fix what you have that’s what I did - eBay Id eBay Item No. 192608039671 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #548198 25th Mar 2020 8:02am
rar110
I have the same problem. I only have one key. Any advice on supplier of a complete key would be appreciated. ______________________________
Post #551190 20th Apr 2020 11:05pm
Danwilderspin
There’s a guy on here bushey I think does a good deal on keys Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #551318 21st Apr 2020 9:02pm
rar110
I tried one from FFRR site vendor. Didn’t work. I could get it to unlock the doors but nothing else. ______________________________
Post #551786 27th Apr 2020 5:48am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
I used to do them -- but passed on the business.
2008 not programmable with IID
It's the barrel locking chip that will catch you out
https://www.facebook.com/landroverkeys/
Https://www.lrkeys.co.uk
either should get you to the same folk Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #551795 27th Apr 2020 9:55am
Danwilderspin
Bushy can it be programmed with sdd - getting the blank keys from China?
Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #551797 27th Apr 2020 10:05am
Danwilderspin
Failing that there’s a load of info on this thread
https://www.rangerovers.net/threads/what-a...st-2111337 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #551798 27th Apr 2020 10:07am
Bushy30
Hi Dan,
The information on that thread is correct CN900mini will read and then write chips -- CN3 are the type of chip required.
Thumbs Up Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #551799 27th Apr 2020 10:20am
Danwilderspin
Bushy - my query is - as it reads one chip then clones it does the car see it as the same key or can you set different seat positions etc? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #551811 27th Apr 2020 12:05pm
Bushy30
Sorry Dan, I hadn't realised I missed a question !
The chip in question doesn't define the key in that way -- if you think about it, it's when you press the unlock button on the remote, programming that function is different and nothing to do with the CN3 chip Wink Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #551814 27th Apr 2020 12:17pm
rar110
Thanks Bushy. ______________________________
Post #551869 27th Apr 2020 8:05pm
Danwilderspin
Thanks bushy might buy one and sell it for £20 less could pass it round the whole forums 😂 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #551875 27th Apr 2020 8:55pm
