![]() | Home > Maintenance & Mods (L322) > Second Battery |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
I have been looking into this and seen a couple of threads on here about people who have done these and looking for some feedback. This is not something I could make myself so looking at available kits to buy and then fit myself.
Thanks for that.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Both options connect the 2 batteries together - just use a different trigger. The first option means they could be connected together when not being charged - not sure if that's a problem with different batteries or not - should be fine. but I'm far from expert - maybe a question for the vendor ?
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
Dan_uk_1984 did this on his (now mine). Look him up on here and read his posts on it.
" I do know that leaving them permanently connected together - even matched batteries - is a bad idea as they flatten each other over time - but not sure how quickly that occurs......"
@Dolphinboy what battery is fitted in the back of your car as trying to sort that out now.
its a smaller one. will go and get a pic when the rain has stopped |
Maccaa Member Since: 03 Feb 2020 Location: Bristol Posts: 38 ![]() ![]() ![]() |
I was interested in this bit of kit (the luxury one) and he has an install video where he explained that you can have two different batteries AGM or otherwise and they don't need to be the same size.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
In solar systems I fit, it’s common to join many multiple batteries with out issue, just charge each one to the same star of charge. Only issue you get is if one starts to fail it will pull all the other batteries down but this is rare on well maintained systems. |
@Maccaa I have ordered the luxury one and will fit the smaller battery in the right hand bin where the tow bar would sit so I have to find a new space for that instead.
zarnd thanks I will probably do the same once Dolphinboy has posted a pic...no pressure |
Roi354 Member Since: 06 Feb 2020 Location: Essex Posts: 32 ![]() ![]() ![]() |
As I said to the guy selling the luxury relay kit online - £65 for a relay and a few wires? He's having a laugh.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
agree this is a joke . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 75 ![]() ![]() |
I wouldent call that luxury (is he serious) kit a dual battery charging / isolator kit in a pink fit .. And wow it is advertised as a way to fix fault codes showing up....
