Home > Maintenance & Mods (L322) > Oil cooler - 3.6 TDV8 |
jonminns Member Since: 07 Mar 2011 Location: Leicestershire, UK Posts: 155 |
Well, got the missus to come and have a look, she solved it first time!
14th Apr 2020 7:39pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Glad you got it sorted sir |
14th Apr 2020 11:26pm |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 |
Interesting Jon, was your leak of water or oil and were you able to find out where exactly it was coming from?
15th Apr 2020 5:03pm |
Hi Nick,
15th Apr 2020 7:07pm |
thanks Jon, very interesting. As you know to see where anything is leaking from in the V is pretty much impossible without dismantling enough to stop then being able to run the engine. Even with a cheap USB boroscope camera with a light on the end I couldn't get anywhere on a finding a location for the leak. There are so many o ring seals around the oil filter housing and PCV assembly as well as the oil cooler that it could be one of quite a few things. Certainly on mine the oil seems to be confined to the left side of the V at the rear and I have sucked out sludgy oil residue from the wells in that side of the rear of the V using an old turkey baster!
15th Apr 2020 8:11pm |
