![]() | Home > Technical (L322) > Trickle charger question |
I have had it on charge for days now and it finally starts getting a decent voltage in the battery. I have a cheap cigarette socket USB charger with voltage indicator and it is finally well into the 12 volt region. Probably a good thing the Optimate takes its time to charge it.
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
I have some reservations about charging a connected battery.......regularly.
TJRL Member Since: 07 Sep 2019 Location: Reading Posts: 198 ![]() ![]() ![]() |
Reading RR P38's post made me think about fitting an isolator on my negative battery post, which would effectively allow for the disconnecting of the battery at the turn of a knob.
My 2003 L322 the only thing I have to reset is the steering angle everything else fires up as normal a quick lock to lock and your done. |
JohnK Member Since: 15 Mar 2020 Location: Hampshire Posts: 61 ![]() ![]() ![]() |
On my 2003 TD6 its the steering angle, windows and sunroof and the date and time.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 870 ![]() ![]() ![]() |
this one looks nice n neat n tidy
I use this exact system......without the fuse though, if I want to charge or isolate the battery two turns on then Green knob and its isolated, this does the same but seems to be some form of anti theft arrangement |
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88 ![]() ![]() ![]() |
The instruction to remove the battery from the vehicle is waffle used to hide some simple physics.
