![]() | Home > Maintenance & Mods (L405) > Deployables - Needed or Not |
Who ever told you that information was wrong sir... No noticeable height difference from the earlier models |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
you do have auto access mode which might help... ... - .- -.
DangerMouseUK Member Since: 03 May 2015 Location: London Posts: 69 ![]() ![]() ![]() |
Ah so the ride height lowers the exact same as on an MY17 then?
The exact same??? It maybe a MM or 2 different dependant as to JLR's software... But as a whole, yes the setup will be like for like with the 17MY... |
Ok yeah cool so probably a better idea to have deployables then! |
normal steps work as well... ... - .- -.
Felstmiester Member Since: 06 Apr 2019 Location: Hertfordshire Posts: 262 ![]() ![]() ![]() |
Do the deployable ones stay out when the cars parked up, or go in when the car is locked and back out when unlocked. Or are they door related?
SS.Lyria Member Since: 01 Dec 2016 Location: London Posts: 257 ![]() ![]() ![]() |
They disappear when locked up, so you lose the protection from wayward door opening from other cars.
Paranoid about it to be honest. Although it’s not used as a daily car so not so bad.
Unfortunately RR drivers seem to be down the pecking order when it comes to receiving sympathetic attitudes from other car owners.
palli Member Since: 27 Oct 2017 Location: Suffolk Posts: 42 ![]() ![]() ![]() |
Is it not still possible to turn the steps off from the screen whilst deployed? 2008 Vogue Black - gone
On my MY14 you can’t do it from the screen but from a switch, it’s a bit of a faff, so I tend not to bother. |
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 555 ![]() ![]() |
Are you possibly getting confused with the SVA ? This does sit 8mm lower. Tony
