Home > Maintenance & Mods (L322) > Part no for in tank fuel filter?
Danwilderspin
Hi all
Trying to find out the part no for the in tank fuel filter on the 4.2 is it the same as the sport for the same engine which is wfl500010?
Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #521910 16th Jul 2019 12:47pm
JohnGalt11
United States 2009 Range Rover Supercharged Supercharged Santorini Black
Late reply, but I thought I'd provide a link to the correct fuel filter for the 4.2 SC (at least for my 2009). It is slightly different than the one for the HSE, which has a silver metal cylinder that looks to be about the size of a thumb on the bottom.
https://www.fcpeuro.com/products/land-rove...-wgc500140
Did you ever swap yours out? If so, what milage was your FF when you did it? Did you have any symptoms before you changed it and did changing it help? 2009 L322 SC
Post #550206 13th Apr 2020 1:04pm
Danwilderspin
I did indeed I just asked the dealer in the end.
It just sits on the top of the tank yes? Surely the se would be the same?
Done 100k... yours? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #550229 13th Apr 2020 4:41pm
JohnGalt11
I ordered the one from the link I posted above, but it hasn't arrived yet. I was talking to my neighbor who is a 20+ year Toyota mechanic and he said that toyota doesn't even change their fuel filters out as a preventative maintenance item anymore because they were having too many instances where the mechanic would accidentally damage the metal fuel line during the filter change and turn a 1 hour $300 task into a 6 hour $1300 task, on the Dealerships' dime because they damaged the line. Now I'm really nervous about doing it if everything seems to be working fine. I've seen some posts about people changing out the filter on the 4.4 HSE, but the 4.2 SC is a whole different setup. I'm considering just sending it back.
Has anyone changed out the fuel filter on their 4.2 SC preemptively, and did it make any difference? 2009 L322 SC
Post #550234 13th Apr 2020 5:50pm
Danwilderspin
Mine was preemptive I guess because the actual fault was a failed cut and at 100k it made no difference at all. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #550238 13th Apr 2020 6:04pm
