Home > Technical (L405) > Air con failed again!
nwmgc
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
My one treat of the lockdown week is to drive to the supermarket Shocked but yesterday in the first hot day of 26 degrees, no cold air Censored
The system was supposedly overhauled under warranty two weeks after I got the FF last October. All the stealer would tell me was that it had cost the sales department ‘a lot’, so whether it was a loss of the new fangled refrigerant or something else, I don’t know. I always keep the system on auto and on the last beloved 322, nary a problem over six years. Obviously, I can’t get it fixed for a while but if anyone has any bright ideas, do tell....
Post #550103 12th Apr 2020 2:34pm
put it in manual and play about with the temperatures.... ... - .- -.
Post #550106 12th Apr 2020 3:05pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Mine had a very small leak in the condenser - which is where most systems fail. It was pressure tested and was fine. It was only when the system was re-charged and started to get hot that the leak showed up.
I was told that if it was re-charged it could last a year, or even more. But only a replacement condenser will fix the problem long term (until it fails next time). Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #550122 12th Apr 2020 5:24pm
Needs the pressures checking to see if it’s lost the gas.
If it has it Needs a dye test to see where it’s leaking. As am said above it is probably the condenser.
If it hasn’t it’s probably Also worth checking to see if the clutch on the compressor is working properly. You can normally tell if it is as there is a small change in engine speed and note when it kicks in. Revs drop a smidge and you may hear the compressor start to spin. There is nothing that can't be fixed with a hammer😜😜
Post #550125 12th Apr 2020 5:29pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Depends which gas it runs on, mine is about £300 for a regas
Post #550143 12th Apr 2020 9:07pm
All 405's are the same expensive gas DrF... Whistle Rolling Eyes
You will need to get the system checked by an AC specialist sir... As said above, check for dye... Condensers suffer with stone damage all the time!
Post #550147 13th Apr 2020 12:19am
nwmgc
Thank you all for the sage advice. I have read that the newer refrigerant is exceptionally leaky and suspect it’s that. It is the sort of thing, though, that when it is fixed, you are always waiting/ worrying that it will fail again! Bring back full fat gas, I say.
Post #550170 13th Apr 2020 9:57am
Andy B
A bit more on Aircon here :-
https://www.fullfatrr.com/forum/topic48202.html
Thumbs Up SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #550171 13th Apr 2020 10:15am
Mine went wrong last year which showed a leak in the condenser so I replaced that! Then it leaked out again and it was traced to an aluminium pipe for the rear AC! Had corroded where a steel clip fixed it in place!!! Good old JLR!!!
Post #550174 13th Apr 2020 10:33am
nwmgc
Thanks for this - my search skills are poor!
Post #550175 13th Apr 2020 10:46am
Weegie
They don't seem to learn. A steel clip for an aluminium air con pipe was a common fault with the D2. Crying or Very sad John
GAP iiD BT
Post #550176 13th Apr 2020 10:48am
nwmgc
Well, my warranty does run until October... Very Happy
Post #550177 13th Apr 2020 10:48am
So does mine but JLR extended warranty doesn't cover AC!!! Rolling Eyes
Post #550249 13th Apr 2020 10:27pm
nwmgc
Hopefully as I have the full Approved (rather than extended) warranty, it will be covered. Gas on its own, is not, but it may well have leaked away from some covered component!
Post #550298 14th Apr 2020 12:58pm
nwmgc
As there is no sign of garages opening anytime soon, I called in wechillanycar.com.
Pretty impressive, I must say. The guy pressure tested and said it was at maximum (I was given a printout with all this), but no gas at all. He was 'surprised' there was no dye visible as the stealer had supposedly tested for leaks at the end of last year.
He refilled with added dye so if there is an escape, there's a chance of finding it. If as, I suspect, there is a leak and the stealer remains shut, I would feel confident to have them back. The guy that came, Mike, has done nothing but car a/c for 33 years (!).
All, I thought, a very reasonable £115 for coming out and doing the work. Oh and it's amazing what a difference a cool interior is - I had almost forgotten!
Post #554315 18th May 2020 12:56pm
