Home > Technical (L322) > td6 gearbox
markglf
td6 gearbox
hello all ive bought a td6 with suspected gearbox fault, drives around in like a limp mode but does go back to normal now and then. after checking the basics autobox level is under level half inch or so and its got auto trans dv1 [gm dexron v1]. what ive read im i right in saying it should have dextron 3 in it. will these cause the problems or is it the gearbox u/s nothing coming up on dash. if so anyone know a good gearbox repair service in lancashire england. thanks in advance.
Post #550046 12th Apr 2020 7:44am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Good morning
My advice as a TD6 owner is to use the oil that BMW originally filled the box with at the factory
You can pick 20L for around £80.
Jim
Post #550047 12th Apr 2020 8:27am
Weegie
+1
From WIKI https://www.fullfatrr.com/wiki/Recommended_Lubricants John
GAP iiD BT
Post #550051 12th Apr 2020 8:36am
markglf
thanks, i will be using the correct oil when its sorted just trying to find out would this oil be the fault or is it the box now u/s
Post #550062 12th Apr 2020 9:36am
jim4244
Well if it were me I would do a double oil change and add a dose of Dr Tranny Just to see if this fixed the problem. It would cost you less than £100 and may resolve your problem.
Jim
Post #550065 12th Apr 2020 10:06am
