![]() | Home > In Car Electronics (L322) > Test PAG Hybrid Tuner? |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
I'd bypass the telephone module and plug the PAG back in, it's usually the telphone module that causes issues ! Current: 2011 FFRR Vogue SE 4.4 TDV8
DonPedro Member Since: 07 Apr 2020 Location: Hampshire Posts: 4 ![]() ![]() |
Thanks Bushy30. I tried exactly that, because others have pointed at the phone module as the likely culprit in other failure cases. In my case, when I by-passed the phone module and re-attached the PAG, the whole system went down again. This re-inforces my suspicion that there is a fault with the PAG (or something associated with the PAG module), but I don't know how to test for this. |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 ![]() ![]() ![]() |
When my PAG TV module failed in my 2011 5.0 S/C, all the rest of the infotainment was absolutely fine and the MOST circuit itself was good, but I just got nothing from the TV - very limited TV options/buttons on the display, and no actual channels.
Re: paulbrown22. Land Rover claim that the serial number of each MOST component is stored on the Central Junction Box (CJB). They claim that each time we turn on the ignition, the Integrated Head Unit (IHU) reads the serial numbers of all modules in the ring and compares with the stored numbers in the CJB. They say we need LR Diagnostics to change stored serial numbers when we replace components.
Nope, I hadn't heard that before, and many other people on here seemed to just replace the TV tuner unit.
Re: paulbrown22 - very interesting. Perhaps LR make the MOST serial number security threat as part of their job creation scheme!
Yes, afraid I gave up with investigating why my original one died, as soon as I put in a replacement that worked!
