Home > Maintenance & Mods (L322) > Where can I buy.....
p-trax
Japan 2011 Range Rover Vogue 4.4 V8 Santorini Black
Castrol SLX powerflow C1 5W-30, other than the dealers.
no joy searching online.
car went into reduced power mode last night, and needs 1.5litres!
either my car is burning a Censored load of oil, or the useless Censored dealer didn't check the fluids before delivery! Gerry
____________________________________________
Arrived>Santorini/Jet FFRR MY11 TDV8
Gone>Stornaway/Ebony MY09 RRS HST TDV8
Gone>Java black/Ebony MY07 RRS HSE TDV6
Post #54967 16th Mar 2011 10:59am
have you tried europarts gerry, and have you checked the dipstick by chance... ... - .- -.
Post #54969 16th Mar 2011 11:11am
p-trax
i will try europarts now.
new model has electronic display of oil level on dashboard screen (between dials). It shows a min/max chart, and displays a text message stating how much oil you have to add.
According to manual there is no dipstick. but it was dark last night so i didn't hunt for it. Gerry
Post #54984 16th Mar 2011 12:18pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Forum sponsor Opie Oils??? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #54987 16th Mar 2011 12:29pm
p-trax
tried opie earlier, no joy. europarts neither.
apparently i need a "specialist supplier"
i guess that means dealer! apparently (according to post on disco forum) the same oil is used in mazda's Gerry
Post #54990 16th Mar 2011 12:36pm
no dipstick, what ever is the world coming to... Laughing
gerry, your range is nearly new and shouldnt be loosing this amount of oil ,so surely the dealer could give you the oil at a discounted cost.. ... - .- -.
Post #55023 16th Mar 2011 2:27pm
p-trax
the dealers are f*<kwits! Gerry
Post #55070 16th Mar 2011 6:00pm
Tim in Scotland
A new TDv8 might use a lot of oil in the first few months. Due to the high carbon content of the block it absorbs oil and there is a warning about it in the manual. Expect up to a litre in 600miles...................... both the new TDv8's I have owned have needed this much top-up within the first 2000 miles and then they haven't used any more oil after that. And yes the 4.4 has an electronic oil level monitor there is no dipstick - mind the wire with plastic beads on it that my 3.6 has isn't much use as a dipstick as it's difficult to read. What Car? this month comments that they sent their car back to the supplying dealership because they didn't read the manual............. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #55079 16th Mar 2011 6:44pm
nbunney
Will this help?
http://www.disco3.co.uk/forum/topic46217.html
Post #55080 16th Mar 2011 6:54pm
p-trax
nbunney wrote:
Will this help?
i'll give it a read, thanks for the link Gerry
Post #55111 16th Mar 2011 10:34pm
