Home > Technical (L405) > Steering Issue
tomo141
Steering Issue
Hi, I'm just after some advice on a steering problem. I have looked through the forum, however i cant find anything which relates to this specific problem.
I have 2013 (63) V6 (AB) had it 3 years with no issues at all. (just 51000 miles) when turning the wheels left and right, it has developed a loud cracking noise. it steers fine, no issues on the road at all.
When manoeuvring, turning left or right, noise appears. When parked, if i got to full left lock, it makes the cracking noise just prior to being at full lock, it's the same on full right lock.
Has anyone experienced similar? It always goes to LR main agent for service.
Any advice would be appreciated. As a key worker it is in daily use, and becoming a concern.
Tomo ------------------------------------------
L460 D350 73 24 model FFRR Autobiography Santorini Black with Shadow Pack
L405 4.4 V8 18 FFRR Autobiography (facelift) Santorini Black with Shadow Pack
L405 3.0 V6 13.5 FFRR Autobiography Santorini Black
L322 4.4 V8 12 FFRR Autobiography Santorini Black (RR Styling Pack)
L322 3.6 V8 10 FFRR Autobiography Santorini Black
L322 3.6 V8 07 FFRR Vogue SE Santorini Black
L322 3.0 I6 55 FFRR Autobiography Santorini Black
Post #549674 7th Apr 2020 9:43pm
tomo141
Had the steering issue diagnosed at LR main dealer - requires new steering rack at a cost of just over £3000.00
Had 4 L322 without any issues. Only ever cost service and tyres.
Post #551043 19th Apr 2020 11:07pm
Ouch, that's very unlucky! Not something ive come across on the 405...
It'll do that if its not bolted down firmly!
Post #551049 20th Apr 2020 12:49am
tomo141
Its certainly going to hurt the pocket. LR did say its rare.
Post #551081 20th Apr 2020 11:21am
do you have bigger than normal wheels on yours Tomo.. ... - .- -.
Post #551084 20th Apr 2020 11:28am
tomo141
Hi Stan, I have 22" turbines. They have been on since new.
Post #551085 20th Apr 2020 11:41am
ok so if they OE then that knocks my theory of after market wheels causing the problem.. ... - .- -.
Post #551088 20th Apr 2020 12:01pm
tomo141
The only possible explanation is a pothole incident earlier this year. It was fine prior to that. Then developed cracking/straining noise which has got progressively worse. ------------------------------------------
Post #551091 20th Apr 2020 12:37pm
i'd be tempted to get a second opinion ...
smacking into a pothole could have damaged a wheel or some suspension part.. ... - .- -.
Post #551095 20th Apr 2020 12:52pm
tomo141
That's good advice thanks, I'm going to do just that, wheel has been checked by KWF no issues, had to have new tyre - which ended up being 4 new tyres while i was at it. Big Cry ------------------------------------------
Post #551096 20th Apr 2020 1:01pm
