Home > Technical (L322) > 2008 3.6 TDV8 V8 CLICK ON KEY
GerryG
Hi
Has anyone experienced a click on key issue. Replaced my inlet manifold and it wouldn't fire, sprayed fuel down the throttle bodies and turned it over, it coughed on turn then just stopped dead, wont turn over at all.
Just clicks on key now
Any ideas would be appreciated!!
Cheers
Gerry
Post #549447 5th Apr 2020 1:13pm
GGDR
Fill in your car details.
Need to know which TDV8
Thumbs Up Cheers, Greg
Post #549449 5th Apr 2020 1:27pm
GerryG
Its the 3.6 model
Cheers
Gerry
Post #549450 5th Apr 2020 1:32pm
Mikey
You've also asked on the Sport forum. Is it a Sport or an L322 were dealing with?
Post #549453 5th Apr 2020 1:52pm
GerryG
Sport Disco Mikey
Thought both forums were the same!!
Post #549460 5th Apr 2020 3:55pm
GerryG
Hi Mike
Narrowed my issue down, the mega fuse had blown, so its cranking now. Sourced an ICARSOFT scanner, and I have codes PO62D, PO62E, Fule Injector Driver open circuit Performance.
Not sure if I was in the right area, so checked wiring loom, cant see anything, there doesn't seem to be a pulse at the injector connectors. ( Awaiting Noid Light kit,) ntried capless bulbs, no steady or pulse light.
Is the PCM a common part to just go? cant understand why she coughed though if PCM was blown?
Have you came across the codes before?
PS My brother lives not too far from you, wasn't aware you had a shop, so I will be bringing it to you for maintenance once she is up and running.
Would like the front ARB'S done, and new brake lines front to back, is this something you can do?
Cheers
Gerry
Post #551062 20th Apr 2020 7:51am
