Home > Off Topic > Mini arc welder on amazon - any good? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3544 |
HI guys,
4th Apr 2020 11:22am |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 |
What sort of things are you planning to do Greg?
4th Apr 2020 8:10pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Note these little arc welders are normally over rated- if it says 140amp’s, it’s likely to be nearer 90-100amp’s maxed out, still enough for 3-4mm Metal |
5th Apr 2020 6:12am |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 329 |
I’d also recommend going with a MIG welder . It will do all that the small stick machines can and much more
5th Apr 2020 8:56am |
thanks a lot guys of the feedback, will check out the mig options.
5th Apr 2020 9:14am |
Note the reason I mentioned flux core for outside and CO2 bottle shielded for inside is because in wind situations the CO2 gas shielding can be blown away, if you weld on a still day or can make up a wind block you will be fine and get better results than with flux core. Some machines do both which may be an advantage.
5th Apr 2020 10:08am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35323 |
bought my youngest son a power devil mig for xmas..all the reviews were positive and it only cost £60....it also has a non live? handle ??. ... - .- -.
5th Apr 2020 10:20am |
Who knew Stan or Corbyn could weld. |
5th Apr 2020 10:26am |
