Home > Maintenance & Mods (L322) > Rear wiper - worn spline?
stuartj9
United Kingdom 2006 Range Rover Vogue TDV8 Java Black
So, I thought the motor was done. However, after inspecting the wiper and taking the motor off, it looks as though the wiper isn't moving properly as the teeth on spline have worn. The good news is that the motor is fine. I've attached some pictures for opinions on this. If I'm correct, can I get a replacement spline for the motor? I know I can get a new arm but don't really want to pay £60, although I know I might have to. Do I have any other options?
Post #549359 4th Apr 2020 1:39pm
The motor will be just fine as it is... Just replace the arm sir Thumbs Up
Post #549410 4th Apr 2020 10:11pm
stuartj9
Thanks for the reply. Does the spline on the motor look OK? It looks a bit worn to me.
Do you also have a link to Ebay for the correct rubber seal for the motor please? It's slightly leaking inside the car. Thank you.
Post #549412 4th Apr 2020 10:13pm
Yes it looks a little worn but put an arm on with decent spline's and im sure it will work fine sir Thumbs Up
Post #549413 4th Apr 2020 10:24pm
stuartj9
Post #549415 4th Apr 2020 10:41pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Here's what I'd do to find the seal.
Go to http://new.lrcat.com
Find the part number for the seal - in this case it looks like it's DYA000010 (http://new.lrcat.com/#!/12119/101499/102939/8152/103023 assuming I've got your car right).
Stick DYA000010 into your favourite search engine.
Your welcome Thumbs Up
Post #549416 4th Apr 2020 11:00pm
stuartj9
Thanks Stu, that's a great site for parts - bookmarked! It's the wrong seal though. I need the one that connects to the motor and water pipe. This is where it's leaking from. Cheers
Post #549417 4th Apr 2020 11:08pm
https://www.fullfatrr.com/forum/topic9792.html
Have a look on here? There is nothing that can't be fixed with a hammer😜😜
Post #549418 5th Apr 2020 12:25am
stuartj9
Cheers. I used the link on there but looks to be gone from Ebay. There's others but I need to get the correct one. I also need the self tappers.
Post #549462 5th Apr 2020 3:36pm
stuartj9
All sorted. Spline cleaned with a blade, wiper arm sanded and resprayed and arm now back to the correct position Thanks to everyone that helped.
Post #550026 11th Apr 2020 7:42pm
