Home > Technical (L322) > Coolant system getting pressurised |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
Have you checked the other coolant pipes to see if heat is getting into them all, just a thought that you might have a blockage somewhere in the system. Is the radiator the same heat all over? |
12th Feb 2020 2:22pm |
nick4275 Member Since: 28 Sep 2018 Location: Bewdley Posts: 68 |
Thanks for the prompt reply.
12th Feb 2020 2:29pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 497 |
Do these have an egr cooler? Cheers
13th Feb 2020 4:45pm |
Er, I’m no expert but I believe they do. Where might you be going with your thinking ? |
13th Feb 2020 5:35pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Sniff test is the best way forward Nick... |
13th Feb 2020 11:57pm |
I'm making a bit of headway. Got the chemical sniff test, sent it back as they sent me blue liquid type. Tested it today and the red liquid went yellow inside a couple of minutes.
20th Feb 2020 5:20pm |
Have a look at this guys videos as he has done what you want to do sir...
20th Feb 2020 8:26pm |
Thanks Craig,
20th Feb 2020 8:46pm |
Absolutely but it worked on his which was the main point 👍 |
20th Feb 2020 10:52pm |
So, 2 bottles of Steel Seal later and things are much better but still not right !
23rd Feb 2020 2:09pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
That sounds like a water pump issue, change the water pump and the thermostat. BMW i3 Electric Car
23rd Feb 2020 2:46pm |
.. BMW i3 Electric Car
23rd Feb 2020 2:48pm |
So i'm still going with this one.
2nd Apr 2020 8:01pm |
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 |
My 2c just quickly...
3rd Apr 2020 1:33am |
