![]() | Home > Technical (L322) > 4.4 TDV8 - Hesitation at 1500 rpm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35490 ![]() ![]() |
anything like this?
kooky1976 Member Since: 02 Apr 2020 Location: Basingstoke Posts: 6 ![]() ![]() ![]() |
Possibly. It doesn't seem to be vehicle speed related; more so engine speed and at exactly 1500 rpm. No symptoms at any other engine speed.
did you find the cause of your DPF red? Bmay be caused by an air leak somewhere, either the 4 pipes on the top of the engine (plenum) or one of the inlet manifold's cracked. get a high pressure smoke test done earliest to rule that out. |
I said this to the workshop and he just pulled a face at me. So I have new symptoms:
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
9.9 times out of 10 this is caused by ai intake air system leak.
Thanks Greg. I will go back tomorrow and push your points.
I had exactly this on my MY2011 and it was the pax inlet manifold cracked. no codes showing. |
Steve if you've had it a week that will be for the garage you bought it of to sort.
Thanks again Greg.
Just a quick update. The workshop found a lose turbo hose connector. Tightened up and everything seems well. Will give it some testing over the weekend to see if all is well.
