Home > Maintenance & Mods (L322) > 2011 Fron Wheel Bearings. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2494 |
They're the same as earlier models using the same bearing part number. |
31st Mar 2020 7:51pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8617 |
I’ve had it done. Aparently a PITA.
1st Apr 2020 7:15am |
Mine's RH was replaced because it was thought to be the only possible remaining culprit for a noise similar to a failed wheel bearing. The non-LR-specific garage had significant difficulty refitting (pulling) the driveshaft into the hub as they didn't have the proper tool. The bearing noise was still there with the new bearing and eventually tracked to 2 brake pipes near the modulator vibrating together because the spacer had fallen out. |
1st Apr 2020 8:31am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
www.advancedfactors.co.uk is the place to find them Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
1st Apr 2020 10:03am |
