Home > In Car Electronics (L322) > 2003 TD6 Noise when radio off
JohnK
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Hi All,
Anyone have any ideas what could be causing a low volume static like noise coming from the speakers when the radio is off?
Its the factory satnav unit and screen with cd autochanger. All works fine except the auto changer which is dead.
You cant hear the static when the radio is on, even at low level.
Post #548921 31st Mar 2020 7:40am
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
Statics noise
Hi,
That noise appears on mine only after I've repaired the radio module BM54 and I fixed it with a noise reduction condenser fited on the the BM54 feed.
Hope this helps
Cheers
Post #551038 19th Apr 2020 9:37pm
JohnK
Thanks for the info, where did you pick up the BM54 feed and im assuming you mean the main 12v in?
Post #551061 20th Apr 2020 6:18am
A.Pires
Is the large wire I suppose is the brown one
Post #551892 27th Apr 2020 11:02pm
JohnK
Update for anyone that has similar issues in the future:
On further investigation I found the amp to be 2 channels down too, drivers side front and rear mid/bass.
I checked and cleaned all the connectors in the boot and doors checked continuity from amp to speaker terminals all ok, same for the earths, no difference to the white noise.
Replaced the amp with one from ebay and the noise is now 99% gone, think thats about as good as its going to get without replacing some expensive bits!
Post #556123 1st Jun 2020 1:04pm
