Home > General > Laying Up Ideas. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
My plan is to not wash the wheels and cover them up when washing the body work to avoid water getting onto discs.
30th Mar 2020 7:18pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3776 |
One of these days JLR will wake up to the idea of a solar charger panel instead of the glass roof panel, particularly for hybrid/ electric cars to keep the batteries topped up.
30th Mar 2020 8:43pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 688 |
Leave it connected is fine.
31st Mar 2020 7:29am |
https://www.disco4.com/shop/tow-electrics-...c-p45.html Click on the drop down in the "charger" box. Select Optimate. Select plug choice in "Plug" - 7 or 13pin Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- Last edited by DrRob on 31st Mar 2020 7:33am. Edited 1 time in total |
31st Mar 2020 7:31am |
John Member Since: 18 Feb 2014 Location: Longfield Posts: 69 |
great, thanks for your reply
31st Mar 2020 7:32am |
2011 5ltr V8 SC stornoway grey, ebony & ivory seats 4.2 SC KAHN (sold) defender 110 SX 2.4 puma (sold) |
31st Mar 2020 7:36am |
If you haven't got tow-bar electrics, there's no reason why you couldn't run a cable from the battery down to the corner of the grill & wire up you're Optima connector there, it'll be discreet enough & again, means you can charge with the vehicle locked safely.
31st Mar 2020 7:37am |
thanks Guys
31st Mar 2020 7:46am |
If it is easier to connect to the rear , because you drive into the garage, rather than reversing in....
31st Mar 2020 7:55am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3824 |
I was wondering given the suggestion above if I should reverse or drive into my garage
31st Mar 2020 9:04am |
Some of the Disco lads have their Ctek connectors from battery tucked under the back edge of the bonnet on the scuttle. They then just pull it out a little and then connect up the Ctek. The Ctek chargers come with a lead with eyelets on one end and the Ctek connector plug on the other. Another option Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1234 |
Thanks , but...... I would expect them to of thought of that and somehow have a non rusting type of metal or whatever.... So if I drive thru a puddle in my driveway I’m a bit b.....d ( techinical term ) Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc He who dies with the most toys wins... |
31st Mar 2020 9:13am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7948 |
As long as you're using them, brake discs dry out & the pads remove any small amount of surface rust.
31st Mar 2020 9:21am |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 317 |
I have my CTEK MXS 7.0 connected to the car via the boot cigarette power socket - seems to work fine. I think this one is live when the ignition is switched off and the car locked.
31st Mar 2020 10:37am |
