Home > Maintenance & Mods (L405) > Battery Conditioner
Page 2 of 5 <12345>
TomV8
United Kingdom 2004 Range Rover Vogue 4.4 V8 Bonatti Grey
Ocean53, you could try “Tanya” . They normally do quick delivery. 2004 L322 4.4 V8 Vogue Bonatti Grey
(205,500 miles and counting.......)
Post #548597 28th Mar 2020 7:24pm
TomV8
Sorry Ocean53, I meant to type Tayna 2004 L322 4.4 V8 Vogue Bonatti Grey
Post #548598 28th Mar 2020 7:25pm
Ocean53 wrote:
Thanks
Amazon no delivery before 25/4
Amazon have deprioritised everything they consider non-essential.
However, there are other sellers on Amazon who will deliver sooner.....
https://www.amazon.co.uk/CTEK-MXS-5-0-Reco...amp;sr=8-2
Post #548600 28th Mar 2020 7:31pm
Phil.
Andy,
Your main battery is in your boot. If you buy the solar panel I have linked to above you can connect a set of wires to the battery permanently that have a plug on the end. When you want to use it you attach the solar panel cable via the plug and stick the solar panel in a window.
The most complex bit is connecting the wires to the battery but once that's done all you do is plug in the solar panel. That's about as simple a solution you can get. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #548603 28th Mar 2020 8:20pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Cheers Phil.
Post #548607 28th Mar 2020 9:04pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Do you guys use a charge controller to prevent discharge and overcharge?
In the L322 there is a cigaretlighter kind of plug always live, can't that be used to charge the battery, or doesn't it work in 2 directions?
remember, non tech here Embarassed
Post #548620 28th Mar 2020 10:23pm
Phil.
Robert,
Battery conditioners (accumate and optimate) and the solar panel I mentioned, automatically adjust the charge to avoid over charging. As apposed to battery chargers which may not have an over-charge control function. MY23 D350 HSE
Post #548624 28th Mar 2020 11:43pm
Robert
OK thanks Phil
Post #548630 29th Mar 2020 8:37am
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
So is it safe to charge (not condition) charge the battery from the posts under the bonnet? The owners manual says battery charging shouldn’t be attempted and to get LR to do it (I know that is probably just revenue creation) but I thought I better check as I know how fussy the BMS can be and I don’t want to have to go to the lengths of removing the battery(s) to charge them.
Also if you charge (or condition) the vehicle using the posts, does it charge just the main battery in the spare wheel well or will it charge the auxiliary battery too?
Thanks
Post #548637 29th Mar 2020 9:27am
I've not had a problem using a CTEK 5.0 - but clearly can't say whether others will be OK or not and whether cheaper / more basic chargers would do some kind of damage - or whether a deeper charge would cause damage.
I've also heard that the car should not be used for jump starting other vehicles - Ive done that too without a problem.
It does raise the question of that the posts are actually for though.....
My understanding is that the 2 barrettes are disconnected when the car is not running - I haven't tested whether that's ignition based, or a voltage sensing sensing relay - if the later, then may well charge both.
I guess if in doubt, disconnect the battery - but I don't think that's entirely straightforward on the L405 either......
Post #548638 29th Mar 2020 9:41am
Ocean53
United Kingdom 2018 Range Rover Vogue SDV6 Corris Grey
I also see in handbook, it says don’t do anything to battery, but then, no one anticipated not using vehicle for so long.
So, just to be sure, there is no live cigarette point in car where one can attach a conditioner?
Second point. I’ve found this from a past life, does anyone know for sure if it is a charger and therefor not a conditioner?
Post #548639 29th Mar 2020 9:42am
Does the one in the boot area stay live ?
It's not possible to provide assurances - the RR electronics seem somewhat fragile to electrical spikes or interference, hence the general advice not to do anything.
The Porsche one is likely safe as their cars are likely as sensitive as RR's - I'd use it, but it's ultimately your decision....
Post #548648 29th Mar 2020 10:28am
i think theres a bit in the WM re battery charging and how to do it.. ... - .- -.
Post #548649 29th Mar 2020 10:32am
Fleagle_UK
Socket in boot doesn’t stay live in my car.
Once engine is shut off it stays live for about 5 mins then cuts. If I lock the car, then power is cut immediately.
Post #548650 29th Mar 2020 10:32am
Fleagle_UK
I did look Stan but didn’t see anything
Post #548651 29th Mar 2020 10:33am
Page 2 of 5 <12345>
