![]() | Home > Maintenance & Mods (L322) > Battery questions |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
If I don't respond immediately to any replies, it's only because I've got to nip out for a couple of hours. Ta. Travelling around in circles again. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3257 ![]() ![]() ![]() |
With a multimeter you will be able to check the voltage that the panel is putting out. Bear in mind that the small ones are really only for trickle charging. Also check that it has a blocking diode in line. Otherwise at night the charge will be draining out of the battery via the solar panel.
Thanks for the info Weegie.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
You need to check the battery at rest voltage, this means no charge or drains etc for a couple of hours, check the voltage which should be ~12.5v for a normal flooded lead acid battery and ~13v for AGM when fully charged then added your solar panel and see if the voltage increases to between 13.5 and 14.5v range.
The Jon Davis I meant was the one I suggested to you for car servicing at Mareuil Ouest.
Thank you Weegie and thank you UR20v for your advice.
