Home > Maintenance & Mods (L405) > Early L405 AB auxilliary battery
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Just in case anyone needs a new aux battery for their early L405 AB I've spent no end of time trying to find the correct replacement. My local garage told me it was an Exide EK151. It's not. this is for the later stop start and is about the size of a small lawnmower battery.. The correct battery as was eventually established by myself is an Exide EK 700. Or quite simply a Halfords 096AGM. For an aux, it's a big battery, but that's what it is.
Post #548175 24th Mar 2020 7:57pm
thankyou for that info Rob.. Thumbs Up ... - .- -.
Post #548181 24th Mar 2020 9:06pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Thank you for sharing.
Great information to know.
Post #548188 24th Mar 2020 10:32pm
Have you replaced the main battery too ?
Mine is still on the original ones, so likely I'll need to do both soon
Post #548212 25th Mar 2020 9:54am
roberlar
Yes I replaced the main battery a few months ago (which was actually still good as I have it fitted to a telehandler now) so the battery monitor obviously doesn't discriminate between the two. The aux battery is genuinely at end of life. The main problem I had is almost all info leads you to the very small EK 151 @ 15ah and 200CCA whereas the correct battery for the early AB (or certainly mine) is the EK 700 @ 70ah and 760 CCA which is vastly different. On top of that you cannot see specification info on the original JLR Exide battery without disconnecting and removing which I was reluctant to do without having the new correct battery to fit due to possible electrical issues. Add to that if you search Halfords and compare their 096 AGM to the L405 (which is the same as a EK 700) it says it will not fit. The same applies to Amazon if you search the EK 700 and most other battery suppliers as well. I seem to recall seeing an image you posted which shows your battery to be the same as mine so as said, that's what it is. The saving grace was an online uk firm called Advanced Factors who show a very useful diagram of the L405, the battery location and battery type. My AB has the executive rear seating with another cooler etc. so maybe that spec together with FBH and so on has higher demands on power hence the big aux battery?
Edit: Just had another look at your image and can see from the seat buttons in the boot you have the normal seat layout so that isn't the reason Confused
Post #548309 26th Mar 2020 8:19am
supershuttle
So my car got two batteries - you learn something new every day Very Happy Geoff
Post #548315 26th Mar 2020 9:49am
Main one is undertake spare wheel. Secondary is here -
Post #548317 26th Mar 2020 10:02am
Weegie
Site sponsor. Thumbs Up John
GAP iiD BT
Post #548322 26th Mar 2020 11:12am
roberlar
Thumbs Up Thumbs Up
Post #548327 26th Mar 2020 11:58am
