Home > Maintenance & Mods (L322) > Leave off EPB for storing? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4307 |
As I won't be using the RR for a while (now working from home) is it worth leaving the EPB "off" whilst it's laid up to stop it seizing to the rear discs? I've read somewhere it can be put in "off" by taking out a fuse???
23rd Mar 2020 9:26am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35381 |
just leave it in 'park'....dont activate the brake. ... - .- -.
23rd Mar 2020 9:31am |
Thanks Stan. For some reason I thought it came on automatically but that's good to know!
23rd Mar 2020 9:33am |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
Yep. What Stan said.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3776 |
Rob/ Stan,
23rd Mar 2020 10:10am |
Page 94 in the drivers handbook tells you how to prevent automatic operation.
Mike.
V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
23rd Mar 2020 10:32am |
Ditto, but I might just take it out for a run tomorrow while we are still allowed out.
23rd Mar 2020 11:50am |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 |
And you and yours too Mike. Current: FF Westminster money pit
23rd Mar 2020 11:52am |
interesting Mike..
23rd Mar 2020 11:55am |
Perhaps I am reading it wrong, but , my interpretation is that when you select Park and switch off ignition it automatically applies the EPB, but as the car powers down, the EPB module depowers to prevent battery drain .
23rd Mar 2020 12:07pm |
so when you start and select drive/reverse you have to release the epb?? ... - .- -.
23rd Mar 2020 12:29pm |
No, you don’t need to touch the brake handle.
23rd Mar 2020 12:36pm |
I'll try it later again but I just put into P and then switched off without applying EPB. Locked car.
23rd Mar 2020 3:07pm |
Just opened it. No red light.
23rd Mar 2020 3:53pm |
