![]() | Home > Maintenance & Mods (L405) > Trailer Breakaway cable on deployable bar |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7968 ![]() ![]() ![]() |
Looping it around the ball seems to be the only option. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8673 ![]() ![]() ![]() |
as above, loop it around the ball.
palli Member Since: 27 Oct 2017 Location: Suffolk Posts: 42 ![]() ![]() ![]() |
Deleted 2008 Vogue Black - gone
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 230 ![]() ![]() ![]() |
The above comment about the carabiner type clip is wrong.
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
The eye on the side of the bar is for the breakaway cable. Looping round the ball is not advised as the weak point is the neck of the ball. I did find that i needed a shorter breakaway cable to stop it dragging on the ground. |
I just went to take a look - I don't know what I was remembering, but you're right - there is an eye on mine |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 ![]() ![]() ![]() |
Hi, mine is a Carabiner and that’s the loop I used for it. |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
DON'T loop it round the ball hitch - if the ball fails the cable could spring off & not apply the brakes.
Off topic, but registration & testing of trailers makes a lot of sense.
