![]() | Home > Technical (L322) > Coolant reservoir - "Check coolant level" |
It can be triggered by a low mix dilution. Needs to be at least 50% water and coolant or stg like that. |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 ![]() ![]() ![]() |
Might be worth checking the coolant level sensor which plugs into the bottom of the expansion tank. The last time I had a job done on my SC the mechanic forgot to reconnect it and I was getting similar messages. 2006MY 4.2 SC
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 595 ![]() ![]() ![]() |
Sorry, I should have said the fault is intermittent!
Closerthanmost Member Since: 27 Aug 2017 Location: Cambridgeshire Posts: 62 ![]() ![]() |
I used to get this, about half a mile after leaving home, and then it would just disappear and not come back again. When it went in for a service last August I mentioned it and the local Indy told me that it was low so they topped it up with water. Message went away and I though no more of it. Last week it came up again, at the same point of the journey, and once again promptly went. It's now happening like that almost every time I go out.
Interesting, mine is a little bit more random, sometimes immediately on start up, most of the time after 5 or 10 minutes and sometimes after a 1/2 hour journey. But it only happens once on a journey and not on every journey.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
This is not true, the sensor is a magnetic reed switch and its not in contact with the coolant. 2007 TDV8 VSE 2003 TD6 gone. 2002 P38a gone 1999 P38a gone 1997 p38a gone 1993 VSE gone 1992 VSE gone 1966 Series 2a with V8 conversion gone |
Thanks, that's my understanding as well, but I will test anyway to make sure my concentration is good.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
“This is not true, the sensor is a magnetic reed switch and its not in contact with the coolant.”
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Nino-Nino did a bench test to prove conclusively that you get low coolant alarm when filled with water, but not when 50% antifreeze is added.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
bigbo, check this post
Thanks, I had seen that post but a useful reminder
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
Having recently replaced my alternator, I lost pretty much all my coolant.
