![]() | Home > Technical (L322) > Think carefully , unusual braking problem |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Further to my issues with handling , the suspension thinks it has to go as high as it can , making it very uneasy driving around , I’m hoping the alignment sorts all this !
Went for alignment but alas the suspension was too high and this can’t be done. I tried to deflate the corners and raised to normal height for alignment (standard height)
Hi everyone , I am looking for a workaround to to remove a front strut to ascertain where the leak is coming from , whether it's the feed hose connection or indeed the bag itself.
Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72 ![]() ![]() ![]() |
Al
Many thanks for video, I have seen it but never watched till the end. I’m hoping I can remove or get access to it especially the top pipe connection . This corner which is the culprit was replaced last August , so I have to prove it’s faulty unless It’s connected badly and can be refitted.
I have managed to get the L322 to to an Alignment with my front nearside still less than was originally set after manual height setting on IID Tool 24mm out .The alignment centre advised a steering angle reset was needed after alignment so this has been done after I reset the height on each corner twice with the door open.
Looks like the leak is from the top seals from behing the damper thread . Dismantled the bag and the seals are all damaged , so the only way I
