Home > Technical (L322) > TDV8 Alternatorh how to change/replacement pics |
Henrik07 Member Since: 14 Apr 2016 Location: Bergen Posts: 63 |
Have you been able to disconnect the electrical connections? You may have to do this by feel, without actually seeing what you're doing. Disconnecting the induction pipe in front of the alternator helped me. I had a stick I used to push down on that pipe as I wriggled the alternator out. It gives you those extra 2mm of clearance.
24th Jul 2019 9:17pm |
briangunn Member Since: 19 May 2019 Location: London Posts: 56 |
I had disconnected the main output, but hadn't got the alternator out enough to disconnect the smaller multiplug.
25th Jul 2019 8:38am |
Stu Jags Member Since: 02 Jan 2020 Location: Oswestry Posts: 7 |
Help, please. fighting with my alternator removal at the moment, how far out will it come before disconnecting electrics. Red terminal on the side and plug at the back ? |
5th Jan 2020 8:51pm |
Got the alternator swapped, very tight fit ! Didn’t need to loosen dipstick, expansion tank or Lower induction hose. Saying all that it looks like it would be easier if induction hose could be removed entirely for the job. Don’t know if it can be removed?
6th Jan 2020 10:25pm |
All back together and surprisingly it works ! Car is much happier now it has a good supply of electricity. One tip, check the O ring on radiator drain plug otherwise when you fill up with coolant and start the engine it dumps your new coolant all over the garage floor ! |
12th Jan 2020 8:50am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 |
Nice work 2016 Skoda Octavia VRS Estate
12th Jan 2020 9:06am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6735 |
Got the alternator pretty much out, with the exception of the electrical connector at the back. How does it release? I’ve seen reference to “squeezing it” but where do I squeeze? I’ve tried a few variations and maybe my fingers aren’t quite strong enough to release it Got - 2017 SDV8 Autobiography in Loire Blue
25th Feb 2020 10:57am |
Yes squeeze the plug and it should just pop off. If memory is correct it’s similar to the plug that connects the fan ? Either way don’t force it like I did and break the plug!
25th Feb 2020 11:07am |
Yes, my fear is that I force it and it breaks.
25th Feb 2020 11:15am |
Quick update to say I’ve now got the new alternator in and tightened up. I’m just awaiting the delivery of a new polyrib belt, since it looks clear the alternator has never been replaced before, so I can reassemble the plumbing.
26th Feb 2020 9:37am |
jimmyhorns Member Since: 17 Sep 2016 Location: Southampton Posts: 4 |
I too started this job just over a month ago now, and its difficult to do on a gravel driveway when all it does is rain.
8th Mar 2020 11:55am |
A lot of people say they struggled to get the alternator out and clear. Maybe I just got lucky, as I just turned it a bit anti-clockwise and it just came out. Getting it back in was equally stress free and I didn’t have to do any of the other dismantling that others have done.
8th Mar 2020 5:42pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
I have just had my alternator fail. A tell-tail of impending failure is an intermittent whine, it’s faint and matches engine speed but only seems apparent when driving. It came and went randomly over the last 2 months. I note others have mentioned a noise.
15th Mar 2020 4:00pm |
At least you’ll have good weather for it
17th Mar 2020 3:42pm |
