Home > Maintenance & Mods (L322) > 05 l322 30d fans query
deltic
Ireland 2005 Range Rover SE Td6 Bonatti Grey
Hi i just replaced the egr thermostat and when testing for a leak is it normal for the fan to come on at start up and run continuously
Post #546949 12th Mar 2020 9:17pm
Which fan...viscous or electric ? .
Post #546955 12th Mar 2020 10:06pm
deltic
Think it was the viscous will check tomorrow i lost no coolant when replacing egr thermostat old one was kaput
i think its been running for months temp gauge never moved out of cold after 100 mile drive new termo made some difference now the hard one ohh
Post #546959 12th Mar 2020 11:11pm
deltic
Yes the viscous fan is staying on at start up is there a way to fix this has it to come out or has it to be replaced it any fuses i can take out to see if it gets to normal temp thanks
Post #546982 13th Mar 2020 11:47am
deltic
Just checked the viscous fan with engine running i can stop it on start up with a piece of cardboard as engine heats up just out of the blue mark on temp gauge its on full cant stop it is it a problem or normal
Post #546985 13th Mar 2020 12:48pm
