Home > General > Interior Door Badge Replacement |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
they look nice dan as you say they look better with the cream trim "RANGEISM WILL NOT BE TOLERATED"
11th Mar 2011 12:52pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Do they fit in the later models? 08MY for example Ian |
11th Mar 2011 1:03pm |
I "think" they were from an 08 or there abouts - I can't be sure without Microcat. If you have a similar badge there then yes they will fit - you may have to cut the tag off the black badge as I did. Or it may fit in the same hole - either way it should be OK. You can get them in green too which would have been my preference if the car didn't already have black badges. What I want is the Range Rover badges from the Evoque - but that's a different story for a different thread for a different day! |
11th Mar 2011 1:25pm |
Thank-you dan Ian |
11th Mar 2011 1:30pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
If i order 4, will they fit both left and right/front and rear? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
14th Mar 2011 9:23am |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
Dan, where are the green ones available from? 2006 Mercedes CLS
14th Mar 2011 5:18pm |
They're on Microcat (dont have it installed on this laptop yet) look at the door fittings and you'll see them. Dan |
14th Mar 2011 7:42pm |
Green badge part #: EKA500060WYY £4.50 from Britcar: http://www.brit-car.co.uk/product.php?xProd=143902 |
15th Mar 2011 12:51pm |
Oooooohhhhh!
15th Mar 2011 6:00pm |
Yup, Like I said, on ours the tag points down, on these it points to the right - so you'll have to cut this off for it to fit and hold the badge in place with a small blob of silicone sealant for easy future removal. I think it looks great with the wood door caps, it finishes the door off nicely. I considered changing to the later door cards, but actually prefer mine now. D |
15th Mar 2011 6:19pm |
Ordered, I'll get some pics when they're on 2006 Mercedes CLS
15th Mar 2011 6:33pm |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 |
Do they fit 2002 HSE models. Mine seem to have just a cream coloured rubber badge saying "airbag" on it.
15th Mar 2011 6:36pm |
So yes, they will replace your badge, with the caveat I gave a couple of posts up. |
15th Mar 2011 6:40pm |
Thanks Dan
15th Mar 2011 6:49pm |
