Home > Technical (L405) > centre console cup holder cover stuck in open position. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
It’s on a click stop. You push it forwards slightly to close it. There is nothing that can't be fixed with a hammer😜😜
25th Mar 2020 9:51pm |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
thanks. I know that The problem I’m trying to explain is that when you push it forward to release it stays in the open position. It won’t slide shut and just returns back to the open position. The damped spring loading is clearly still “on catch” . I can’t see anything visibly blocking its return to the close position. 😟 |
28th Mar 2020 4:41am |
DrDill Member Since: 08 Apr 2017 Location: Cornwall Posts: 66 |
I had this problem, it was one of the wooden stirred sticks had slipped under the side and stopped it sliding back |
29th Mar 2020 8:19pm |
Right. An afternoon of nice weather and fixed it. Here's what I found.
12th Apr 2020 4:38pm |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 383 |
Hi Fleagle, I know this is a older post but I am having the same problem with my wife's 2014 and my 2016. Slider cubbie doors are both not working. Mine sometimes returned but i tried spraying some silicone on sides where rails are and it just made things worse. What I was wondering, after looking at your pictures, is that the spring is mounted on top of the assembly not the bottom so I am wondering if I remove the climate panel if I can see down underneath it to get to the spring?? I am a little afraid to try and take apart the console. Thx! Mike |
13th Aug 2021 1:57am |
Hi Mike.
13th Aug 2021 6:39am |
Thanks Fleagle, after you repaired it, did it work smoothly? Before I tried lubing the sides with silicone, you would push it from the open position and it would very slowly close even stopping a few times before reaching the full closed position. I believe they changed the mechanism in 2019 eliminating the sell close on the console cubby and also removing the side pocket doors on front and driver doors, one of which i replaced.Thx! Mike |
13th Aug 2021 3:35pm |
Yeah from 2019 they cheaped out and removed the soft close mechanism and made it a manual close. Yuk!! - presumably because of the number of fails they had had with the poor design.
13th Aug 2021 5:36pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
Mine started acting up after my phone fell from the vent and landed on the sliding door. I took out the lower climate control and it doesn’t help much. So I was frustrated and smacked down on the door…partly bc I was frustrated and partly bc a drop on it caused the issue…””so another shock would fix it right?? Hah. Well I heard something drop that sounded like a screw. Now it opens and clicks/holds…but when you push it to close it shuts like a damn guillotine. I’ll take it apart one of these days 2014 FF Autobiography 5.0 SC
14th Aug 2021 12:40am |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 281 |
So I’ve fallen prey to the dreaded sticking cup holder. My problem stemmed from spillage of a sticky drink (Long mountain climb, leg cramps, Lucozade, drink bottle too small to be held properly in the cup holder + an emergency braking stop….. never Lucozade in the car again!).
22nd Sep 2021 9:52am |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 |
This thread was tremendously helpful for me when I did this job so let me add a few pics of the screws and bolts that need to be removed. There are also a lot of clips and some of these fell deeper down under the console than my magnet on a stick could reach. Buying some spare in advance could be a good idea, but losing a few doesn’t matter. I have also added a couple of pics of my solution to stop the spring from moving too much sideways.
22nd Oct 2022 7:49am |
