Home > Technical (L322) > Adjusting headlights for continental driving?
Always
Hi all.
I've had a good search, but I'm still left scratching my head on this one...
I've got an 07 L322, but the previous owner upgraded the headlights to (I think) 2010 style.
I'll be driving on the continent shortly, and I'm aware that the headlights have an adjuster lever inside to change the beam pattern. I've read on here that they are set 'up' for uk, and 'down' for Europe, and I've also read that the European setting 'flattens' the beam pattern.
So... I was tinkering in my darkened garage the other day, and the levers didn't seem to correspond with the above (TBF, it was a while ago now, and I can't exactly remember what was what...).
Is there a definitive guide anywhere?
Thanks in advance.
Rich
Post #546726 10th Mar 2020 7:35pm
QuebecTango
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
Hi
I have a 2011 vehicle had same issue - worked it out with the aid of the beam setter at work.
Setting for driving abroad ,
O/S click lever up.
N/S click lever down
Hope this helps
Post #546752 11th Mar 2020 5:43am
both levers should be up for the UK and down for euroland..
i cant find anything in the owners manual about having left and right levers separate... ... - .- -.
Post #546763 11th Mar 2020 8:13am
Always
Big Cry
And there, in the space of two posts, is why I'm confused! Laughing
The bit of manual that I read said something like "reverse the levers for driving on the continent". Which is useless info IMHO unless you've just bought the car brand new and have an impeccable memory.
My garage tinkering led me to a similar conclusion to what Qubec Tango said, but I've actually got no idea what sort of beam pattern I'm supposed to be aiming for!
Admittedly, both up, or both down, would be brilliantly logical....!! Question Question
Post #546765 11th Mar 2020 8:33am
Weegie
There is a difference depending on the model year. Up to 2009 it was down for Continent and up for UK (not sure about 2010).
It was then changed to down for UK and up for Continent.
If your adjusters are as in this photo then it us for Continent and down for UK :
 John
GAP iiD BT
Post #546767 11th Mar 2020 8:39am
this from the WM clearly explains the tourist lever,
Post #546769 11th Mar 2020 8:42am
dazza1983
What Weegie said is correct,
i know this from personal experience of driving around for almost 1 year with my headlights set to european beam lol.. Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #546784 11th Mar 2020 11:13am
sorry but you're both incorrect..
its always been both levers up for UK and down for euroland.
my above extract is from the 2009-2012 WM btw...
this is from the 2006-2009 WM,
the 2013 L405 onwards have flat beams with no adjustment necessary... ... - .- -.
Post #546787 11th Mar 2020 12:36pm
Weegie
Maybe Dazza needs to change his login to Dazzle. Rolling with laughter Rolling with laughter John
GAP iiD BT
Post #546789 11th Mar 2020 1:55pm
Always
Stan
My confusion deepens... On the one hand you're saying 'both' up or 'both' down; and on the other hand you're posting something that says (middle paragraph of both of the WM extracts) that the levers are delivered in different positions depending on whether it is the right-hand light or the left-hand light. And one simply reverses the position for the tourist setting.
I appreciate that it is easy to leap to the conclusion that they are talking about RH drive or LH drive cars, but they're not, they're on about left or right lights with their LH and RH.
I'm still struggling though, because I've no idea whether my lights are 'Halogen' or 'Xenon', or 'Bi-Xenon'! I'm pretty sure they're not AFS (adaptive?).
When I started to tinker with mine, I do recall the levers were in opposite positions (one up, one down).
Rich
Post #546793 11th Mar 2020 2:22pm
the up/down refers to the base range rover halogen headlights...
there are very few of these about and nearly all range rover headlights have xenon bulbs...
you have xenons Andy.. ... - .- -.
Post #546795 11th Mar 2020 2:30pm
dazza1983
Sorry Stan you are incorrect.
Please see my post from a month or so ago.
My levers has to be pushed down to get the correct beam pattern.
https://www.fullfatrr.com/forum/topic54330.html
And for the original poster. The easiest way for you to get the correct beam pattern is to park opposite a fence or garage door etc and move the levers untill you see a beam pattern like in the link I’ve posted above. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #546799 11th Mar 2020 3:00pm
read the WM's dazza... ... - .- -.
Post #546801 11th Mar 2020 3:06pm
Always
Daz
Just read your other thread. Great pics.
So does the correct UK beam pattern have two 'bumps'? Then flat for Europe?
The logic in my head says that you'd have a bump on one side for driving on the left, and a bump on the other side for driving on the right...
I'm going to tinker some more tonight after dark and see what mine are like.
Thanks all.
Rich
Post #546802 11th Mar 2020 3:08pm
dazza1983
You should see a step / bump on both sides buddy yes..
The drivers side should step up and meet the sameline as the passenger side which will then go on to step up.. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #546806 11th Mar 2020 3:41pm
